2000 Monaco Signature Series Caesar
Coach has (2) Slides and is a 43ft CAESAR Model with a 500 HP Cummins ISM, on a Monaco Roadmaster Chassis w/10,000 lb. hitch setup for a motorcycle lift (not included).
Has a 2-speed Hi/Low exhaust brake, 1550 lb/ft torque Allison HD-4060 6-speed World transmission with electric touch shifter and two overdrives with only 83,000 miles on the Roadmaster semi-monocoque chassis with air glide suspension, 10 new airbags, 10 new Bilstein shocks, Blue Ox steering stabilizer, and tag axle Anti-lock air actuated brake system Brand new Aug 2020 Toyo 295 – 22.5 tires on aluminum wheels. Engine and 22.5 kw Gen Set always maintained by Cummins of Tulsa, and the Allison Transmission always maintained by Allison of Tulsa/United Engines. Chassis work has all been done by Tulsa Spring   Normal maintained work has been done by Wades RV or Tulsa RV predominately.
COACH
One button HWH air leveling system, Seamless one piece molded fiberglass roof, 150 gal fuel tank, 100 gal fresh water tank, Lighted storage compartments with slide-out trays & insulated compartment doors, Two slide-outs (Super Slide Kitchen & Living Room) and (Queen bed slide). Has three roof mounted 13,500 BTU air conditioners with heat pumps (2 brand new and 1 almost new), also a completely rebuilt electrical side and engine side 12.5 KW Onan Quiet Diesel generator with an almost new Xantrax Freedom 3000 watt Sine Wave Inverter and 90 watt solar panel system.
INTERIOR
Tilt and telescoping steering column with “smart wheel” burl & leather steering wheel, newly reupholstered designer leather heated driver and passenger seats with power lumbar and passenger side electric footrest. New Kenwood in-dash stereo, navigation, with blue tooth, USB input, & back up camera monitor, nearly rebuilt Aqua-hot heating and hot water system, Insta-hot water system, custom Corian counters with dual sinks, Corian window sills, Corian night stands, and custom Corian shower. Hidden built in safe, “Huge” rear closet with electric clothing “carousel” like you see at a Dry Cleaners, Ekornes “Stressless” recliner, Whirlpool washer/dryer (separate units).
Upgraded natural solid wood cherry cabinets throughout 40” Samsung Smart flat screenTV,  Bose Lifestyles sound system with AM/FM/CD, Winegard “Trav’ler” self seeking satellite dish ($2,500), Propane (3) burner cook-top with a huge gas oven below and newer GE convection, & microwave oven, Four door Norcold refrigerator with a (1) year old new cooling unit.
Some of the work I have done to this coach in the past few years includes:
* Replace all Airbags (air ride system on coach)
* Replaced all the Bilstein Shocks with new ones.
* Rebuilt and/or replaced every brake caliper.
* Replaced several rotors and machined remainder to clean manufacturers specs.
* All new brake pads all around
* Had ride height set to factory specs.
* (8) New Toyo Tires in August of 2020
* Reupholstered all furniture inside except the recliner.
* New Custom Made Duvet for Master Bed ($1k)
* Rebuilt Exhaust Brake Controls
* Installed new cooling system on the Norcold Refrigerator
* Installed (2) new Roof Air Conditioners under my ownership in Sept 2019 and previous Owner replaced other one before putting into storage.
* Generator has a brand new electrical side installed and Cummings of Tulsa is just finishing up the engine rebuild, so Gen Set will be like brand new again. (We got caught in the hurricane that hit New Jersey and Pa in August 3rd and in an effort to keep from getting blown over, I pointed the front of the coach into the wind while gen set was running, and water got blown into Brushes and Rings and shorted out the armature.  I took the coach to Cummings of Tulsa to replace the complete electrical side and rebuild the three cylinder Yanmar Diesel Engine as well to keep it reliable for years to come.  This work will be complete next week.
https://library.rvusa.com/brochure/00Signature.pdf
When u look at the brochure, my layout is the 43 Caesar SO. The description of the coach is listed as a 43’ Monaco Signature Series - Caesar Version with 500 HP Cummings and Allison Automatic Transmission
I have the original manuals and paperwork showing the MSRP of $427,000. Located in Tulsa, Ok and offered for sale at $70,000 That’s almost $30k under NADA’s average retail value. Please either contact me at rcdresser@cox.net or text me at (918) 261-2661
Thank you in advance for looking at our coach. We hate to sell it but my health issues require it.
Link to post
13 hours ago, Chargerman said:
Looks like a very nice well kept Coach. Best of luck with the sale.
Thank you, I appreciate that.
Link to post
