CountryB Posted March 8, 2020 Share Posted March 8, 2020 Here a page from the wiring diagram. I hope it is still legible when you zoom in. Good luck Link to comment Share on other sites More sharing options...
Chargerman Posted March 8, 2020 Author Share Posted March 8, 2020 Thank you Country B. I can read it. You certainly are the go to guy for Monaco specs and info. Really appreciate it! Link to comment Share on other sites More sharing options...
Chargerman Posted March 12, 2020 Author Share Posted March 12, 2020 Received my new side mount cameras today. Very small👍 Add them to my stash of items for upcoming Spring upgrades when I get back up to the Coach. 1 Link to comment Share on other sites More sharing options...
Mike Rizzo Posted March 12, 2020 Share Posted March 12, 2020 I have my BOYO cameras in my "spring" stash ... Just waiting for someone in the group to complete the change over so that I can get a hands on of the change over .. what wires to use.. how to use them etc.... Looking forward to the switch over. Mike 2005 Dynasty w/ 2019 Wrangler Link to comment Share on other sites More sharing options...
Chargerman Posted March 12, 2020 Author Share Posted March 12, 2020 Unfortunately, won’t get to mine until May. I will post my install when I get there. Link to comment Share on other sites More sharing options...
pwhittle Posted April 5, 2020 Share Posted April 5, 2020 (edited) I installed my BOYO VTK230HD cameras this weekend. A few notes: - I made a fitting from aluminum on my my mini lathe. - Main outer diameter was 0.98” to fit in where the old camera was mounted. Overall length was 0.9” - I left a flange of just under 1.25” diameter that was .200” thick - Through hole was large enough for the M8 thread on the mounting stud. - I bored the center to .625” to a depth of .7” to accommodate an M8 coupling nut. - I drilled out most of the threads on the M8 coupling nut so it was easier to pass the connector through it. - The coupling nut was used so that I would not need to bore the adapter out to accommodate a socket. - Wiring was pretty simple. I cut the blue loop so there were no parking lines. - I cut the connector and wire from the old camera with as much wire as possible. It is only about 4” long. - I used an RCA to screw terminals so it was a solderless installation. (WGCD 20 PCS Phono RCA Male Plug to AV Screw Terminal Plug Connector Audio Video Adapter https://www.amazon.com/dp/B06XKWFQQF/ref=cm_sw_r_cp_tai_S2MIEbRQXQKS3) - The wires on the old camera connector are: Red 12V, Black GND, Clear, Video signal. The white and green are not used. The shield on the clear video is just trimmed off. - I pulled most of the new wiring into the mirror arm after taping it to keep it all together to make it easier to get the new wiring in, - Picture is color and seems to be good in my driveway. Much better the old B&W picture. - I have not driven it yet, but will report when I do Edited April 5, 2020 by pwhittle 1 Link to comment Share on other sites More sharing options...
Chargerman Posted April 5, 2020 Author Share Posted April 5, 2020 Looks good and the picture looks better than the old cameras for sure. Looking forward to working on mine on a few weeks although it looks like we won’t be going out for a bit. Link to comment Share on other sites More sharing options...
Chargerman Posted May 11, 2020 Author Share Posted May 11, 2020 We are back north at the coach and starting on my Spring to-do list. Assembled and installed the mirrors with the replayed arms I had done and the marker light in place of the head banging ugly brick cameras. Then I installed the new cameras and wired everything up. Cameras are super small. My only wish would be to be able to paint them. I had to take a peak inside the old camera just to see the size of the actual camera components. After seeing them it’s pretty easy to see that the manufacturer could have made the house much smaller and sleeker. If anyone needs a brick camera let me know I and I will send it over. Link to comment Share on other sites More sharing options...
Steven P Posted May 12, 2020 Share Posted May 12, 2020 Steven, Looks good. Can you post a pic of the video monitor w the camera on? Thanks 1 Link to comment Share on other sites More sharing options...
Chargerman Posted May 12, 2020 Author Share Posted May 12, 2020 Here you go. Doesn’t look as clear as it does outside. Coach is still in the garage and lights were not all the way warmed up when I took the pics. Link to comment Share on other sites More sharing options...
Chargerman Posted May 12, 2020 Author Share Posted May 12, 2020 All of the lines in the first pic are not from the camera. I will post better pics when I get the Coach outside. Link to comment Share on other sites More sharing options...
Steven P Posted May 13, 2020 Share Posted May 13, 2020 Still looks good. Just to check, you did not already have cameras in those locations, correct? If you did, how was the paint underneath? Link to comment Share on other sites More sharing options...
Chargerman Posted May 13, 2020 Author Share Posted May 13, 2020 (edited) Correct. There were not cameras where I now have them. They were in the mirrors. I kinda wish I had purchased the more expensive cameras that Tadi sells. Not because of the picture quality but for the better housing. These housings are rubber and not paintable. Still ok though since they are so small. Edited May 13, 2020 by Chargerman Link to comment Share on other sites More sharing options...
