Ivan K Posted December 14, 2020 Share Posted December 14, 2020 16 minutes ago, Dr4Film said: Brett, I have used a pin or needle to push through the wire I want to probe for voltage. Then just use your alligator clipped to the probe. Unless you deal with shielded cables, these piercing probes remove all the frustration Link to comment Share on other sites More sharing options...
Brett63 Posted December 14, 2020 Author Share Posted December 14, 2020 Ok, I just probed the wires and here is what I got. J1 25 - Acc on no buttons pushed 5.185V Hi/Lo pushed 3.224 Intermittent pushed 3.230 J1 24 - Acc on no buttons pushed 5.015 Hi/Lo pushed .875 INT pushed 1.217 On the steering wheel Blue wire tests......acc on 5.66, (Hi/lo...3.11) (intermittent 3.11) (Off 1.82) (Washer 2.34) Violet wire tests....Acc 4.90 (Hi/lo .766) (Int 1.10) (off 1.12) (washer 1.11) The steering wheel test values were compared to the test values on the VIP test sheet under Table 1 in this tech sheet.....For Software version 1 (vipwheels.com) Link to comment Share on other sites More sharing options...
Frank Bergamo Posted December 14, 2020 Share Posted December 14, 2020 Brett, this may sound to simple, did you check to see if you have power at the wiper motor? Hope this helps. Link to comment Share on other sites More sharing options...
Frank McElroy Posted December 14, 2020 Share Posted December 14, 2020 Brett, all those voltages when keys are pressed are way too low. I think Fred's suggestion that +5 feed voltage going to the keypads is likely running low when a keypad is pressed. You can verify by measuring the voltage on the red wire. It should stay at 5 volts when you press a key. Also the white wire on that same plug should stay at 0 volts when a key is pressed. Link to comment Share on other sites More sharing options...
Brett63 Posted December 14, 2020 Author Share Posted December 14, 2020 40 minutes ago, Frank McElroy said: Brett, all those voltages when keys are pressed are way too low. I think Fred's suggestion that +5 feed voltage going to the keypads is likely running low when a keypad is pressed. You can verify by measuring the voltage on the red wire. It should stay at 5 volts when you press a key. Also the white wire on that same plug should stay at 0 volts when a key is pressed. Are you saying the voltages on the steering wheel plug or the 24/25 wires are too low. The ones on the steering wheel plug pretty much correspond with VIP's given voltages. Link to comment Share on other sites More sharing options...
Frank McElroy Posted December 14, 2020 Share Posted December 14, 2020 Brett, it's time we took the detailed discussion offline. I sent a reply to your email address. Link to comment Share on other sites More sharing options...
slemnah Posted December 15, 2020 Share Posted December 15, 2020 The problem with piercing a wire is that unless you seal the wire afterwards which many people do not do, it then becomes an area ripe for water intrusion and corrosion. I have those same tools but try to only use them in a dire situation. I then use liquid electrical tape and seal the hole really well. Link to comment Share on other sites More sharing options...
Brett63 Posted December 15, 2020 Author Share Posted December 15, 2020 3 hours ago, slemnah@sbcglobal.net said: The problem with piercing a wire is that unless you seal the wire afterwards which many people do not do, it then becomes an area ripe for water intrusion and corrosion. I have those same tools but try to only use them in a dire situation. I then use liquid electrical tape and seal the hole really well. These are in the front run bay, if water gets in there I have more issues than 2 pierced wires...lol Link to comment Share on other sites More sharing options...
Brett63 Posted December 17, 2020 Author Share Posted December 17, 2020 Wanted to update the group. What I found was low voltage to the steering wheel, 3.88 instead of 5v. After doing some talking and planning I ordered a 12v > 5v DC/DC converter and will find the power wire to the steering wheel in the run box and cut it and insert the new power supply and pull 12v from any of the 12v lugs int he front run box. We believe that will solve the steering wheel issue. I have lost both sides to it now. Thanks to all the assistance I received. Link to comment Share on other sites More sharing options...
Ron Kellam Posted December 10, 2022 Share Posted December 10, 2022 I have the same problem with the same coach, 09 Monaco Signature Commander IV. Wipers are intermittent. I mostly seem to have the wash and the set interval buttons working but no hi/lo. One diagnosis was that when the wheel gets tilted the wires got stretched and contact was lost. Further diagnosis by Oregon Motor Coach Center in Eugene, OR seem to to lead to an intermittent ground connection between the clock spring and the the chassis ground. They tested all the connections in the steering column and think the problem lays with the clock spring itself. They have patched it by grounding the clock spring ground to the steering wheel and it seems to be mostly working again but still no hi/lo. Works when it is warm outside and no so much when it is cold. My theory is things expand when they warm up and perhaps making the ground connection through various U - joints in the steering column. I couldn't wait for a Clock Spring to be ordered and arrive in time for them to install it as we were on the way to CA. So I have ordered a new clock spring which I just got today to see if that fixes it. Now to get a steering wheel puller and the time to install it. Got the clock spring through Veurinks RV. angela@veurinksrv.com or direct 616-965-9627. It listed their part number on the invoice as 16616943 for clock spring 190063. $335.00 + S&H. Also see douglasautotech.com under number 1900043 for installation info. Hope this works as this has been a problem for us for some time now. Link to comment Share on other sites More sharing options...
