Bob Nodine Posted January 30, 2020 Share Posted January 30, 2020 I looked at the latest parts list and did not see any entries for a parking brake release valve. Ours is leaking and will diapate all the air in about 8 hours. This is not surprising because we have over a 112,000 miles on the coach. Wonder if anyone knows a good part number for this valve. I guess when we get to Lazydays I will remove it and see if I can purchase one. Link to comment Share on other sites More sharing options...
Highwayman Posted January 30, 2020 Share Posted January 30, 2020 Findmyrvparts.com has listings for the brake valves about $50. or $60. You can search by make and model for Monaco parts. Link to comment Share on other sites More sharing options...
Warren B Posted January 30, 2020 Share Posted January 30, 2020 Bob Mine was a Haldex KN20031. Link to comment Share on other sites More sharing options...
daveyjo Posted January 30, 2020 Share Posted January 30, 2020 Are you sure it is the valve? My coach leaks down in probably less than 8 hours. I have replaced a lot of air fittings in the past due to air leaks. (Have replaced the valve, too.) Link to comment Share on other sites More sharing options...
Bob Nodine Posted January 31, 2020 Author Share Posted January 31, 2020 (edited) 12 hours ago, daveyjo said: Are you sure it is the valve? My coach leaks down in probably less than 8 hours. I have replaced a lot of air fittings in the past due to air leaks. (Have replaced the valve, too.) Thanks for the replies guys. Dave, since I can sit in the drivers seat and hear it leak air and then move it around to slow the leak to the point I can't hear it I think it is a bad valve. I have over 100,000 miles in the seat of this coach and that valve has been cycled quite a few times. See you at the Gathering. Edited January 31, 2020 by Bob Nodine Link to comment Share on other sites More sharing options...
Steven P Posted February 1, 2020 Share Posted February 1, 2020 Bob, When I changed out my park break sensor I had a small leak until I got it tight enough and it quit. Like mine, yours may just need some tightening due to vibrations. https://shop.findmyrvparts.com/monaco-rv-pressure-switch-park-brake-SM1C66RWP28-p/190050.htm Link to comment Share on other sites More sharing options...
rpasetto Posted February 1, 2020 Share Posted February 1, 2020 If it's the "Haldex KN20031" it's available here: https://www.finditparts.com/products/368639/haldex-kn20031 Link to comment Share on other sites More sharing options...
Bob Nodine Posted February 2, 2020 Author Share Posted February 2, 2020 22 hours ago, Steven P said: Bob, When I changed out my park break sensor I had a small leak until I got it tight enough and it quit. Like mine, yours may just need some tightening due to vibrations. https://shop.findmyrvparts.com/monaco-rv-pressure-switch-park-brake-SM1C66RWP28-p/190050.htm Steve, Its not the pressure switch leaking but the valve that the pressure switch is attached to. 13 hours ago, rpasetto said: If it's the "Haldex KN20031" it's available here: https://www.finditparts.com/products/368639/haldex-kn20031 Thanks Rick. I plan to pull the valve when we get to the Gathering and should be able to tell what it is. See you there. Thanks Link to comment Share on other sites More sharing options...
Sjholt12 Posted April 22, 2020 Share Posted April 22, 2020 I replaced mine (Haldex KN20031) 3 times in 198750 miles and it is due again. They wear out. Link to comment Share on other sites More sharing options...
CTerry Posted April 23, 2020 Share Posted April 23, 2020 Mine was doing the same thing on our trip from picking up our motorhome when it was new. Removed it and took it to our local Peterbilt dealer. They did not have one that was as cheap as the Monaco part but had an exact fit of much better quality. I am sure any truck parts p;ace could replace that valve. Link to comment Share on other sites More sharing options...
fastark46 Posted July 22, 2023 Share Posted July 22, 2023 Does anyone have a part number of the parking brake air valve portion for a 2006 Dip TKS Sorry - just looked above and saw the haldex part number YKS Link to comment Share on other sites More sharing options...
Steven P Posted July 22, 2023 Share Posted July 22, 2023 Google Nason Park brake switch to see if it matches. . This is what I used. Price went up of course. https://rveliteparts.com/products/rev-rv-10119016-park-brake-switch?utm_source=google&utm_medium=shopping&utm_campaign=mid-performers&gad=1&gclid=Cj0KCQjw_O2lBhCFARIsAB0E8B-QPuV6-orv-zwBpcDNgvyYUiWCHak7cJpRyLQEhA1VlcFQCIsrpZIaAg-5EALw_wcB Link to comment Share on other sites More sharing options...
Happycarz Posted July 23, 2023 Share Posted July 23, 2023 Bob, you are good at taking things apart. Maybe you could replace the O ring in the stem. There must be a reason the Haldex KN20031 comes with a spare O ring. Mine will hiss sometimes when applying the parking brake. I twist it a bit and it stops. As soon as it gets to the top of my list, I’ll address it. Meanwhile lead the way and let us know how it works out. If it doesn’t, shop the above number for the replacement. https://vanhorntruckparts.com/pp-1-style-dash-valve-plastic-170-kn20031.html?gclid=EAIaIQobChMIxdmpjaWlgAMVwAytBh0KGwauEAQYAyABEgITBvD_BwE https://www.finditparts.com/products/368639/haldex-kn20031?srcid=CHL01SCL010-Npla-Dmdt-Gusa-Svbr-Mmuu-K368639-L134&srcid=CHL01SCL010&gclid=EAIaIQobChMIxdmpjaWlgAMVwAytBh0KGwauEAQYASABEgKkW_D_BwE Link to comment Share on other sites More sharing options...
