Nathan Posted February 5, 2020 Share Posted February 5, 2020 HI Monacoers - I've got an issue with one of wipers (driver's side). I had one guy look at it and he said the issue was that the "teeth" connecting the motor to the wiper assembly were worn down. Anybody ever experience this? Do I need a new wiper motor? Blade assembly? Connectors? Tks! Nate Atwood Monaco Knight 40PDQ Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted February 5, 2020 Share Posted February 5, 2020 17 minutes ago, Nathan said: HI Monacoers - I've got an issue with one of wipers (driver's side). I had one guy look at it and he said the issue was that the "teeth" connecting the motor to the wiper assembly were worn down. Anybody ever experience this? Do I need a new wiper motor? Blade assembly? Connectors? Tks! Nate Atwood Monaco Knight 40PDQ You may need a new link to replace the original link attached with a nut to the "hardened" splined shaft of the wiper motor. If/when the nut that holds that link it in place loosens... the softer "teeth" in the link connecting the motor to the wiper assembly can "strip out". However sometimes simply cleaning out the splines, (on the shaft of the motor), and then re-tightening the nut will force new threads into the softer metal link. Link to comment Share on other sites More sharing options...
genemenne Posted February 7, 2020 Share Posted February 7, 2020 A photo would be very helpful. See attached:https://autoplicity.com/2195712-anco-wiper-blades-16-wiper-armspartsassm?gclid=EAIaIQobChMI0pyGw9q_5wIVT_DACh2PZwU5EAQYBiABEgLqfvD_BwE. Is this what you are describing? If so, this knurled drive can be replaced as shown. Let us know. Gene Menne, 2004 Knight Link to comment Share on other sites More sharing options...
Hypoxia Posted February 7, 2020 Share Posted February 7, 2020 The arm installation instructions on mine are "Torque to 35 FT Lbs. wait 45 minutes and re-torque to 35 FT Lbs." They are Wiper Technologies arms on mine. Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted February 7, 2020 Share Posted February 7, 2020 2 hours ago, Hypoxia said: The arm installation instructions on mine are "Torque to 35 FT Lbs. wait 45 minutes and re-torque to 35 FT Lbs." They are Wiper Technologies arms on mine. When "replacing the link", (aka: "in new link installations"), torquing the nut as described forces the "hardened" spline on the motor shaft into the tapered bore in the "softer" metal link. Link to comment Share on other sites More sharing options...
Steven P Posted February 8, 2020 Share Posted February 8, 2020 Mel, I know yours is not this model, but I found this recall on my year coach. Wonder if you had a similar one? https://auto-recalls.justia.com/monaco-coach/diplomat/2006/08v070000/index.html Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted February 8, 2020 Share Posted February 8, 2020 3 hours ago, Steven P said: Mel, I know yours is not this model, but I found this recall on my year coach. Wonder if you had a similar one? https://auto-recalls.justia.com/monaco-coach/diplomat/2006/08v070000/index.html Steven P To my knowledge there have not been any recalls dealing with my coach. Link to comment Share on other sites More sharing options...
johncvandoren@gmail.com Posted February 10, 2020 Share Posted February 10, 2020 (edited) On 2/8/2020 at 6:59 AM, Steven P said: Mel, I know yours is not this model, but I found this recall on my year coach. Wonder if you had a similar one? https://auto-recalls.justia.com/monaco-coach/diplomat/2006/08v070000/index.html Will the Late Great Monaco still perform this recall repair? John V 06 Knight 40DFD Edited February 10, 2020 by johncvandoren@gmail.com Link to comment Share on other sites More sharing options...
Dr4Film Posted February 10, 2020 Share Posted February 10, 2020 9 hours ago, johncvandoren@gmail.com said: Will the Late Great Monaco still perform this recall repair? Monaco has been dead for years now so the answer is no. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted February 14, 2020 Share Posted February 14, 2020 You might try contacting https://www.amequipment.com/heavy-duty-wiper-assemblies Link to comment Share on other sites More sharing options...
