Karl Hampton Posted February 19, 2020 Share Posted February 19, 2020 I recently had my drivers side (the arm rest area) - instrument panel rebuilt (not the dash panel). While that came out well, one casualty was my “idle up/idle down” switch (see below). Note that part of the switch probably 2 prongs, are broken off (total should be 6 prongs?). It is 1” long by 3/4” wide. Inscribed as follows as best I can read it: 9803 L203 COLD CONTACTS Q.1A 125VAC-DC 1AMP 28V MAX ************** MICRO SWITCH FREEPORT ILLINOIS AML 20 SERIES **************** So far I haven’t found anything, including at Northwest supply to replace it (size wise). I didn’t use the switch that much, so one solution would be to abandon it. However, it occurred to me that someone on the forum might have one to sell or know where to look for one, so any input is appreciated. Thanks Karl H - 1998 Signature Link to comment Share on other sites More sharing options...
gwl24651 Posted February 19, 2020 Share Posted February 19, 2020 Try "zoro.com" 1 Link to comment Share on other sites More sharing options...
Pampero Posted July 9, 2020 Share Posted July 9, 2020 This is a plain rocker switch. Hold down or hold up to made contacts. Newer coaches have Carling switches, Just Google the brand Link to comment Share on other sites More sharing options...
larry.jervis@att.net Posted July 13, 2020 Share Posted July 13, 2020 Karl, Digikey.com is great site to find Rocker Switches from numerous manufacturers. Larry, 2004 Diplomat 36' Link to comment Share on other sites More sharing options...
miacasa_2000 Posted July 13, 2020 Share Posted July 13, 2020 Karl Spemco is another great company for switches , lights, etc. they carry many brands. https://spemco.com/ Roy 2003 Dynasty Link to comment Share on other sites More sharing options...
Karl Hampton Posted July 13, 2020 Author Share Posted July 13, 2020 (edited) I was able to find an electric repair shop the was able to replace the switch through Micro Switch (the original manufacturer) and it now works fine. Thanks for all the help. It was a rather convoluted combination of switches, wiring and parts, but they figured it out. I also acquired a 99 Executive wiring manual, which luckily matched my 98 Signature wiring. I also had the DS plastic switch panel rebuilt, which is where the switch and others reside. karl H Edited July 13, 2020 by Karl Hampton Link to comment Share on other sites More sharing options...
Dr4Film Posted July 14, 2020 Share Posted July 14, 2020 You most likely have realized by now that there were only 4 prongs needed on that switch not 6 like you were wondering about on your first post. It should be a simple momentary switch, two prongs to increase idle, two prongs to decrease idle. Link to comment Share on other sites More sharing options...
Karl Hampton Posted July 14, 2020 Author Share Posted July 14, 2020 I think we concluded that the extra two prongs were the supply for the light bulbs for illumination - as all the switches on the panel are illuminated, so not needed, but aesthetically pleasing 😎 Link to comment Share on other sites More sharing options...
