Neil Loveless Posted March 2, 2020 Share Posted March 2, 2020 Hi, does anyone know where we can find a replacement back up light for our '05 Beaver, it's a sealed beam rectangular shaped bulb with no numbers of any kind on it. I've been to auto parts stores and found bulbs of similar size but the glass lense is too thick not allowing the chrome trim ring that holds the bulb in place to fit. Thanks for any suggestions, Neil. Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted March 2, 2020 Share Posted March 2, 2020 2 hours ago, Neil Loveless said: Hi, does anyone know where we can find a replacement back up light for our '05 Beaver, it's a sealed beam rectangular shaped bulb with no numbers of any kind on it. I've been to auto parts stores and found bulbs of similar size but the glass lense is too thick not allowing the chrome trim ring that holds the bulb in place to fit. Thanks for any suggestions, Neil. Neil Loveless Someone on safarifriens.org will have the correct part number for that sealed beam light. BTW you can slightly enlarge the opening in the chrome ring to fit one of those "bulbs of similar size", (with a Dremal tool) Link to comment Share on other sites More sharing options...
Mel S - '96 Safari Posted March 3, 2020 Share Posted March 3, 2020 (edited) On 3/2/2020 at 6:55 AM, Neil Loveless said: Hi, does anyone know where we can find a replacement back up light for our '05 Beaver, it's a sealed beam rectangular shaped bulb with no numbers of any kind on it. I've been to auto parts stores and found bulbs of similar size but the glass lense is too thick not allowing the chrome trim ring that holds the bulb in place to fit. Thanks for any suggestions, Neil. Neil Methinks "p/n H9406 sealed beam bulbs" are exact replacement Back Up, (aka: Rear Flood), light bulbs for your '05 Beaver: https://www.amazon.com/GE-Lighting-H9406-Tractor-Sealed/dp/B002CYXKV8 and: https://www.amazon.com/Eiko-H9406-Halogen-12-8V-150mm/dp/B009RTYGB4 and: https://www.napaonline.com/en/p/LMAH9406OR....https://www.napaonline.com/en/p/LMAH9406 Edited March 3, 2020 by Mel S - '96 Safari correced links Link to comment Share on other sites More sharing options...
Neil Loveless Posted March 4, 2020 Author Share Posted March 4, 2020 Hi Mel, thanks for this information, boy does this help! Neil Link to comment Share on other sites More sharing options...
