CountryB Posted March 3, 2020 Share Posted March 3, 2020 I'm looking for a replacement for the Aladdin "Tank Levels" display. This is the unit located in the Wet Bay. It is part number 38050168. If anyone have replaced their Aladdin system and has this item - I would like to buy it from you. Thanks Link to comment Share on other sites More sharing options...
Guest Cruzbill Posted March 3, 2020 Share Posted March 3, 2020 Saw one listed at Visone salvage, $250! Maybe worth checking around other salvage yards. Link to comment Share on other sites More sharing options...
CountryB Posted March 3, 2020 Author Share Posted March 3, 2020 Thanks for the reply. I did contact Visone last week to buy it but they don't have any in stock. That's where I got the photos from. They show parts on their website that are not available . I've checked the other salvage company's "websites" (but did not call them). Link to comment Share on other sites More sharing options...
Dennis H Posted March 3, 2020 Share Posted March 3, 2020 Have you checked SeeLevel? Their complete unit cost $199 with new sensors etc. The sensors attach OUTSIDE the tanks and are superior to the Aladdin INSIDE sensors for accuracy. The SeeLevel system also monitors battery and LP in addition to your black, grey and fresh water. If you're happy with the Aladdin system they have an attachment available for about $100 more that merges theirs with the Aladdin. Best of luck... yeah, I had the same 'issue' with Visone. I think they must be lonely....Dennis Link to comment Share on other sites More sharing options...
Guest Cruzbill Posted March 3, 2020 Share Posted March 3, 2020 Ok, Here is a longshot; Silverleaf Electronics in Albany Or. They make electronics that completly replace Aladdin, might have some 'take offs' lying around. Worth a call. https://www.silverleafelectronics.com/ Link to comment Share on other sites More sharing options...
CountryB Posted March 3, 2020 Author Share Posted March 3, 2020 I'm aware of the SeeLevel and Silverleaf products, but I don't want to replace the Aladdin system. The Aladdin system and tank level monitoring works fine (tank levels can be displayed on the TVs or dash monitor). My plan is to add the "Tank Level display unit" to a new location (that's if I can get one). Link to comment Share on other sites More sharing options...
CountryB Posted March 5, 2020 Author Share Posted March 5, 2020 I found one. I ordered it from AZ RV Salvage. Link to comment Share on other sites More sharing options...
Guest Cruzbill Posted March 5, 2020 Share Posted March 5, 2020 Mike, Glad you found one. Now for the wiring; The display has a 6 pin port but only one port, so you can't 'daisy chain' from your existing display to the new display. Does the joystick have the same wiring as the display? If so, that would make the wiring pretty simple. I like the idea of a display inside, I think I'd try to mount one in the small cabinet above the door where the inverter control is now. Good luck on the project! Link to comment Share on other sites More sharing options...
CountryB Posted March 6, 2020 Author Share Posted March 6, 2020 (edited) The Aladdin components interconnect using a "Bus Tap" (p/n 38020885) and a short jumper harness (p/n 38040101 for the 3ft length). The connector ends are the same. You can replace a Joystick with a Tank Level display using the same wiring harness connector, but if you wanted to add an additional display/unit you would need to find a Bus Tap with an unused plug (or buy another Bus Tap) and get the appropriate length wiring harness. Also - I should mention the "Tank Level Display" unit I just bought is part number 38050167 (not 38050168) for $100. The seller says he doesn't know what the difference is between the ...168 and ...167, but they look identical. So I'm taking a chance. Edited March 6, 2020 by CountryB Link to comment Share on other sites More sharing options...
