Nevada Rob Posted September 11, 2021 Author Share Posted September 11, 2021 A little update. I replaced the command board with a Flight Systems board. Great customer service from Flight Systems. Install was maybe 20 minutes. Ran the generator for 4 hours with all three A/C units cooling with fan on high, refer and Magnum charger running. Not a single hiccup or stall. I did not replace any fuel lines or other items. The command board was the problem. On a side note, when I removed the coolant recovery tank to install the board I discovered the coolant tank was cracked and leaking at the threaded inserts. There goes another $175 for a replacement tank. Link to comment Share on other sites More sharing options...
