isptbart Posted March 25, 2020 Posted March 25, 2020 On our return trip home from NV I began to experience an intermittent problem with my Power Gear Electronic Leveling System. The problem is - after I set the brake & turn on the leveling system at the keypad, I get a blinking light warning to "Engage Parking Brake". No leveling options will work while I get this flashing light! As a result, I have to leave the coach as is for the night w/o the ability to level. Does anyone know what could be the problem, part to replace or even the possibility as to how I can effectively wire up a work around? Since I have a Brake light on the dash I would like to just wire a work-around to bypass this issue.Suggestions please.Thanks!Bart from VA07 HR 42PLQ Scepter - 400 ISL07 GMC 2500HD in tow
Vicwhit3 Posted March 26, 2020 Posted March 26, 2020 I bet it is simply the switch on the brake pedal arm. Mine would do the same and I could get it working by tapping/touching the switch. The switch is a simple open contact and seems to get some layer of corrosion that is enough to prevent current flow. I never did get around to replacing the switch with something better. Good luck. Vic Whitmore 06 Monaco Monarch
Bob Nodine Posted March 27, 2020 Posted March 27, 2020 On 3/25/2020 at 7:43 PM, isptbart said: On our return trip home from NV I began to experience an intermittent problem with my Power Gear Electronic Leveling System. The problem is - after I set the brake & turn on the leveling system at the keypad, I get a blinking light warning to "Engage Parking Brake". No leveling options will work while I get this flashing light! As a result, I have to leave the coach as is for the night w/o the ability to level. Does anyone know what could be the problem, part to replace or even the possibility as to how I can effectively wire up a work around? Since I have a Brake light on the dash I would like to just wire a work-around to bypass this issue.Suggestions please.Thanks!Bart from VA07 HR 42PLQ Scepter - 400 ISL07 GMC 2500HD in tow Most likely problem is the Nason switch under and screwed into the parking brake valve. Not difficult to replace.
woodylmiller Posted March 28, 2020 Posted March 28, 2020 Have you tried re-setting the "brain" by turning off your batteries and then back on? I've never had the problem your having, but I had a constant fault beep while in motion, it would clear up for a while if I turned of both battery disconnects and then back on. Woody Miller 09 Dynasty Regal IV
[email protected] Posted March 28, 2020 Posted March 28, 2020 On 3/25/2020 at 4:43 PM, isptbart said: On our return trip home from NV I began to experience an intermittent problem with my Power Gear Electronic Leveling System. The problem is - after I set the brake & turn on the leveling system at the keypad, I get a blinking light warning to "Engage Parking Brake". No leveling options will work while I get this flashing light! As a result, I have to leave the coach as is for the night w/o the ability to level. Does anyone know what could be the problem, part to replace or even the possibility as to how I can effectively wire up a work around? Since I have a Brake light on the dash I would like to just wire a work-around to bypass this issue.Suggestions please.Thanks!Bart from VA07 HR 42PLQ Scepter - 400 ISL07 GMC 2500HD in tow Could be three things: Brain $450 Wire $250 Switch $50 This is the parking brake plunger air valve. Replaced it and all OK.
docdalen Posted March 28, 2020 Posted March 28, 2020 isptbart I had the same problem on my 2006 Knight. I had to remove and replace the following in order to correct the problem: Brake pressure switch located on the air pressure valve that is used to set the parking brake.($60 for the switch.)
lotosrggp1 Posted March 29, 2020 Posted March 29, 2020 I would first check for clean tight connections and good grounds.
Steven P Posted March 29, 2020 Posted March 29, 2020 Last year, mine did the same thing. I replaced the parking brake pressure sensor and no issues since.
