Trinidaddave Posted October 14, 2021 Share Posted October 14, 2021 We picked up this coach in late February 2021 and have spent long hours getting familiar with systems, changing fluids, belts, filters. Lately I had searched my owners manual for the location of my pump and reservoir location. Manual stated it was in the drivers side compartment just behind the rear tire. Well no compartment there, my side radiator occupies that space. I researched all the forums, downloaded information on Monaco coaches 2004-2006 with similar equipment. I was able to locate the pump and reservoir in the generator bay buried between the headlights and the step motor mechanism. I added dextrin III per instructions in owners manual, 1/2 quart. This solved my issue of bong alarm activating on rough roads and sharp turns. I hope this information helps someone with similar issues. Link to comment Share on other sites More sharing options...
Jim Bob Posted October 14, 2021 Share Posted October 14, 2021 I think I figured out what you were referring to... the leveling system? Link to comment Share on other sites More sharing options...
Trinidaddave Posted October 14, 2021 Author Share Posted October 14, 2021 1 hour ago, Trinidaddave said: We picked up this coach in late February 2021 and have spent long hours getting familiar with systems, changing fluids, belts, filters. Lately I had searched my owners manual for the location of my pump and reservoir location. Manual stated it was in the drivers side compartment just behind the rear tire. Well no compartment there, my side radiator occupies that space. I researched all the forums, downloaded information on Monaco coaches 2004-2006 with similar equipment. I was able to locate the pump and reservoir in the generator bay buried between the headlights and the step motor mechanism. I added dextrin III per instructions in owners manual, 1/2 quart. This solved my issue of bong alarm activating on rough roads and sharp turns. I hope this information helps someone with similar issues. Yes, correct. My leveling system. It wasn’t a test, but I failed to read my post before I sent it. Thanks for figuring it out so quickly. 1 hour ago, Jim Bob said: I think I figured out what you were referring to... the leveling system? Yes, correct. My leveling system. It wasn’t a test, but I failed to read my post before I sent it. Thanks for figuring it out so quickly. Link to comment Share on other sites More sharing options...
redstickbill Posted October 14, 2021 Share Posted October 14, 2021 I also found out low fluid level was my problem with the alarm going off when I made a turn or went over railroad tracks. I found the answer here many years ago when I had an 02 Diplomat. The reservoir on that coach was in the compartment aft of the drive tires on the drivers side. Bill B 07 Dynasty Link to comment Share on other sites More sharing options...
