Ivylog Posted October 28, 2021 Share Posted October 28, 2021 6 hours ago, 96 EVO said: Nope. My 08' has the fuel tank, followed by the 100gal fresh water tank, and AH in the first bay Guess I should have said around 2006 Monaco moved the fuel tank on the S-10 chassis (Dynasty and above) to the second bay. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted October 28, 2021 Share Posted October 28, 2021 (edited) 7 hours ago, Ivylog said: Guess I should have said around 2006 Monaco moved the fuel tank on the S-10 chassis (Dynasty and above) to the second bay. Make sense! I would have preferred if they had at least moved the fresh tank and AH closer to the rear axles, but I do have great access to service my AH, and, still have a few hundred lbs to play with before reaching front axle limit. Have a friend with a Tiffin Bus which has the AH about the centerline of the coach, in a narrow bay, behind the cord reel ! Edited October 28, 2021 by 96 EVO Link to comment Share on other sites More sharing options...
Ivan K Posted October 28, 2021 Share Posted October 28, 2021 Our 00 Sig has 200 gal tank in second bay past steers and holding tanks in the very last bay just before drives. Nothing but batteries and drivetrain past the tags. Link to comment Share on other sites More sharing options...
Bill C Posted December 2, 2021 Author Share Posted December 2, 2021 (edited) Here are my weights with 40 PSI on the tag. Unfortunately I did not have the 1000 pound Motorcycle on the rear when I weighed my coach (specifically addressing the tag weight). Next time I load it I will re-weight). Edited December 2, 2021 by Corkman Link to comment Share on other sites More sharing options...
Ivylog Posted December 2, 2021 Share Posted December 2, 2021 With the bike on I would not increase the tag’s pressure so the drive supports most of the extra weight. Link to comment Share on other sites More sharing options...
Bill C Posted December 2, 2021 Author Share Posted December 2, 2021 Will try it Thanks Link to comment Share on other sites More sharing options...
Paul J A Posted December 2, 2021 Share Posted December 2, 2021 2 hours ago, Corkman said: Will try it Thanks Do the re-weigh and be done with it. I bet you take some weight off the steer. Link to comment Share on other sites More sharing options...
