philcarrell Posted October 29, 2021 Share Posted October 29, 2021 I need to adjust the ride height on my 08 Exec with the valid system. Is the procedure the same as the HWH system. I did it on my 04 Windsor. I tried to download the file but my browser said it was spam Link to comment Share on other sites More sharing options...
Old Dog Posted October 29, 2021 Share Posted October 29, 2021 I have a 2007 Executive and in my owners manual the actual ride height dimension wasn't included. I went back to the 2006 owners manual for the procedure and actual height dimension. I doubt the measurement changed over that time frame. 2006 seems to be the last year that info is available in the owners manual, no idea why. The 2006 manual can be found on the Monaco website and contains a lot of useful info. Subject has been discussed extensively on this forum as well. Hope this helps, Don Link to comment Share on other sites More sharing options...
Ivylog Posted October 29, 2021 Share Posted October 29, 2021 Doesn’t make any difference which leveling system you have…you’re adjusting the ride height valve/rod The S-10 chassis is 9” front/rear but I went to 10” on the front so the front cap clears curbs better when making tight turns. Link to comment Share on other sites More sharing options...
Steve P Posted October 29, 2021 Share Posted October 29, 2021 @Old Dog Don - I need to read that manual and website. Can you post the pdf of the manual or the url of the webpage? The full width mudflap/rockguard on my '08 is dragging so bad on bumps and cornering it has worn off the rubber on the bottom edge about 2 inches. 1 minute ago, Ivylog said: Doesn’t make any difference which leveling system you have…you’re adjusting the ride height valve/rod The S-10 chassis is 9” front/rear but I went to 10” on the front so the front cap clears curbs better when making tight turns. S-10 chassis? Mine has a Roadmaster RR8R chassis ... I guess I need a different manual? Link to comment Share on other sites More sharing options...
philcarrell Posted October 29, 2021 Author Share Posted October 29, 2021 4 hours ago, Old Dog said: I have a 2007 Executive and in my owners manual the actual ride height dimension wasn't included. I went back to the 2006 owners manual for the procedure and actual height dimension. I doubt the measurement changed over that time frame. 2006 seems to be the last year that info is available in the owners manual, no idea why. The 2006 manual can be found on the Monaco website and contains a lot of useful info. Subject has been discussed extensively on this forum as well. Hope this helps, Don 4 hours ago, Ivylog said: Doesn’t make any difference which leveling system you have…you’re adjusting the ride height valve/rod The S-10 chassis is 9” front/rear but I went to 10” on the front so the front cap clears curbs better when making tight turns. Thanks Link to comment Share on other sites More sharing options...
