Wrayj1 Posted October 30, 2021 Share Posted October 30, 2021 I have the Dometic Ac/heat pumps with the dual zone comfort control thermostat on my 2007 Holiday Rambler Endeavor. In zone one the heat pump is not showing up on the thermostat, zone two has cooling, furnace, fan and heat pump. Everything works in zone two and everything but heat pump in zone one. Has anyone had this situation, if so what was the fix? Thanks for any help on this. Ray Link to comment Share on other sites More sharing options...
Ivan K Posted October 30, 2021 Share Posted October 30, 2021 (edited) If it truly is a heat pump unit, the dip switch (likely #7) up on the unit may not be set. Unless it used to work and then you may try thermostat reset? Edited October 30, 2021 by Ivan K Link to comment Share on other sites More sharing options...
nvrtoofast Posted October 30, 2021 Share Posted October 30, 2021 There are also two pigtail usually with two small wires in each. I believe each one controls the reversing of the pump. Like Ivan K said there are Dip switches that need to be arranged accordingly. Link to comment Share on other sites More sharing options...
Wrayj1 Posted October 30, 2021 Author Share Posted October 30, 2021 Yes, it worked previously, zone 2 works. Has anyone done the reset, I tried turning it off and holding the zone and the mode switches, but no luck. Is there a different way to rest it? Link to comment Share on other sites More sharing options...
nvrtoofast Posted October 30, 2021 Share Posted October 30, 2021 Apologies Beyond my knowledge. Link to comment Share on other sites More sharing options...
Wrayj1 Posted October 30, 2021 Author Share Posted October 30, 2021 Where are the dip switches located? Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted October 30, 2021 Share Posted October 30, 2021 22 minutes ago, Wrayj1 said: Where are the dip switches located? On the roof remove the plastic AC cover, right front side there should be a metal electrical box, under that cover on the circuit board are the dip switches. They are labeled and if you make any changes you'll need to do a reset. Those little switches are delicate so be gentle with them. Link to comment Share on other sites More sharing options...
Wrayj1 Posted October 30, 2021 Author Share Posted October 30, 2021 Ray, would the dip switches on both units be set the same? Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted October 30, 2021 Share Posted October 30, 2021 14 minutes ago, Wrayj1 said: Ray, would the dip switches on both units be set the same? Well, I don't know. When I replaced my AC units I just set them the same way my old units were set. I would take a look at the dip switches on your front unit. I can't recall if one of the dip switches is for heat pump but I would think there is one. Link to comment Share on other sites More sharing options...
Wrayj1 Posted October 30, 2021 Author Share Posted October 30, 2021 The rear unit is the one that is working I'll see how it's set. Thanks again. Link to comment Share on other sites More sharing options...
vito.a Posted October 30, 2021 Share Posted October 30, 2021 (edited) Probably a different model than yours but the dip switches are the same. Look at Fig 23 on page 13. 6/14/18 640312 640315 CCC 2 3312020 Electronic Control Kit Ducted 3105007 Air Conditioner Installation Instructions (dometic.com) On this model switch #7 is for the heat pump. As Ray said, they are delicate. What is difficult to understand is if it worked before, the dip switch didn't move by itself. I'd clean ALL the RJ11 (telephone cord) connections with some contact cleaner and do a thermostat rest. Black switch on the bottom off. Hold down top and bottom buttons while turning it back on. FF in display. Then release and check your options. Best of luck! Edited October 30, 2021 by vito.a Link to comment Share on other sites More sharing options...
