RS lakeshore Posted November 4, 2021 Share Posted November 4, 2021 I believe the motor for the power chord reel is bad. The chord retracted slowly and the motor smelled hot. Got the chord in an have not used since. It appears that the plumbing manifold would have to be moved in order to access the power reel. Wondering if any one has done this and would appreciate input. Thanks Link to comment Share on other sites More sharing options...
Jdw12345 Posted November 4, 2021 Share Posted November 4, 2021 On my 05 Dynasty you can access the back of the power cord drum/recoil from and access panel in the bay ahead of it, that access panel is also for the Aqua Hot, yours certainly could be different. Link to comment Share on other sites More sharing options...
Donflem Posted November 4, 2021 Share Posted November 4, 2021 On my 07 dynasty platinum you can get at it from the access panel. Link to comment Share on other sites More sharing options...
Paul J A Posted November 4, 2021 Share Posted November 4, 2021 (edited) All the basement vertical sidewall panels in the basement can be removed. Fasteners usually located at the corners and there may be more. I refastened them in place with Black Velcro. I also had several that were in tracks, and could be moved by hand. Edited November 4, 2021 by Paul A. Link to comment Share on other sites More sharing options...
Rick A Posted November 4, 2021 Share Posted November 4, 2021 In my 06 Monaco I had to remove the whole overhead panel in the water closet. That involved a lot of plumbing and maneuver. Link to comment Share on other sites More sharing options...
RS lakeshore Posted November 5, 2021 Author Share Posted November 5, 2021 I definetly will check out side wall access. There is my manual pull out tray next to it. Thanks Link to comment Share on other sites More sharing options...
brokenarrow1244 Posted November 8, 2021 Share Posted November 8, 2021 My reel is through the closet drawer area and very difficult to gain access, and to work on is quite difficult as well. I had to replace the gears. You might prep for that while in there. Link to comment Share on other sites More sharing options...
RS lakeshore Posted November 9, 2021 Author Share Posted November 9, 2021 My thanks to Paul A. There are sliding panels in the basement area to the left of my service center which is a big help. Even have access to Amtrol tank to check air pressure only to find out the bladder is bad. Will have to replace tank. Still trying to get motor off of chord reel very tight in there. Thanks Link to comment Share on other sites More sharing options...
Donflem Posted November 9, 2021 Share Posted November 9, 2021 Hey, Richard did you find a new motor? I think I might need a new one also. Don Link to comment Share on other sites More sharing options...
brokenarrow1244 Posted November 9, 2021 Share Posted November 9, 2021 no I did not require a new motor, My symptoms were the reel did not retract, but you could hear the motor running. Also the switch was not operating smoothly but only needed a little lube. Getting the assembly out was hard, getting it back in was really hard. Shoreline Reel model RV5036, that was my model number. There is one person that makes a repair kit for the reel. I was thrilled to find him as the price of a new one is pretty expensive and much more intensive to completely replace. Link to comment Share on other sites More sharing options...
Donflem Posted November 9, 2021 Share Posted November 9, 2021 Can I get the info on the repair kit? Link to comment Share on other sites More sharing options...
brokenarrow1244 Posted November 9, 2021 Share Posted November 9, 2021 jondel1234@yahoo.com this is the email address that allowed me to contact him. Then we spoke on the phone. Link to comment Share on other sites More sharing options...
Donflem Posted November 9, 2021 Share Posted November 9, 2021 Thank you Link to comment Share on other sites More sharing options...
RS lakeshore Posted November 10, 2021 Author Share Posted November 10, 2021 22 hours ago, Donflem said: Hey, Richard did you find a new motor? I think I might need a new one also. Don I am still looking at glendinning have a difference in part # from online store an their tech gave me. Also waiting to hear back from Amequipment. Link to comment Share on other sites More sharing options...
RS lakeshore Posted November 10, 2021 Author Share Posted November 10, 2021 Glendinning has the rcl cablemaster motor #wp150-01 at their online store for $112.00 so far that's all I have found. Link to comment Share on other sites More sharing options...
gpafox@att.net Posted November 10, 2021 Share Posted November 10, 2021 I have a 2004 Monaco Windsor and on my first run out I forgot to unplug the cable from the campground supply box. I called Monaco who told me it would be $1800 to replace the reel plus labor. So I called the manufacture and explain what I had done. He told me not to feel bad because that happens to the motor home manufactures all the time as the techs always forget to unplug. He the manufacture of the reel told me for $125.00 he would send me a new one and to send him back the damaged one at no cost to me. It only took me 40 minutes to install the new on. Do you think Monaco was making any money? Link to comment Share on other sites More sharing options...
Donflem Posted November 10, 2021 Share Posted November 10, 2021 Gerald is this something you did recently? I think that’s a good deal. I will have to see who makes mine and check it out. Don So mine is working but I have to shove it in to keep it going. I’m not sure if it’s the reel are if it’s the motor. I thought the motor would be easy to start with. I was wondering what the best way to troubleshoot it would be? Link to comment Share on other sites More sharing options...
