Analyte Posted November 12, 2021 Posted November 12, 2021 (edited) Hello, Looking at my LR slide, the front near the drivers seat doesn't fully compress the inner seal when extended like the rear section. I did some searches and found various threads regarding Lippert and HWH Slides. Did Monaco use a specific type for all of the LR slides, or Is there an easy way to tell which type I have? I'm still new to this RV, and the data card doesn't specify which is on the coach. Thanks, Kerry Edited November 12, 2021 by Analyte typo
Dr4Film Posted November 12, 2021 Posted November 12, 2021 Is your slide electric or hydraulic? My slides are all electric. Can you see below inside the bay as to whether the slide has butted up against its stop or not? I believe my slides are Power Gear slides.
timaz996 Posted November 12, 2021 Posted November 12, 2021 I have the same coach. You have a hydraulic operated slide out by HWH there is adjustment bolts in each arm front and back if you need to move the front out further you should be able to adjust it with those bolts.
Analyte Posted November 12, 2021 Author Posted November 12, 2021 19 minutes ago, Timaz996 said: I have the same coach. You have a hydraulic operated slide out by HWH there is adjustment bolts in each arm front and back if you need to move the front out further you should be able to adjust it with those bolts. Thanks, I wasn't really sure what I had. Are the adjustment bolts accessible in the storage bays or some other way. The bottom of the slide is smooth so not sure where to start looking. Thanks!!
timaz996 Posted November 12, 2021 Posted November 12, 2021 The adjustment bolts are in the arms them self when you have the slide out you will see them
Analyte Posted November 12, 2021 Author Posted November 12, 2021 3 minutes ago, Timaz996 said: The adjustment bolts are in the arms them self when you have the slide out you will see them Ok, I'll take a look tomorrow during the day. Thanks again!
Donflem Posted November 12, 2021 Posted November 12, 2021 I have a problem with my passenger side rear slide it’s dragging on the bottom to much crushing the seal,it also leans a little to much doors don’t stay open. I was wondering if anyone knows how to adjust? Don 2007 Dynasty
Analyte Posted November 13, 2021 Author Posted November 13, 2021 Ok, I looked under the room and see the support arms. At the end there are nuts and bots I suspect for alignment, and then midway there is a window in the arm likely where the piston resides. Anyone have a link to an HWH video I could use to determine how to move the front side of the room out further to compress the inner seal? I found one thread where a guy explained you could back off a nut and use an allen wrench to move in/out, but I'm not seeing anything like that on the arms pictured.
timaz996 Posted November 13, 2021 Posted November 13, 2021 (edited) The one midway in the arm is the bolt you’ll adjust to move that end of the slide out or in. The one you were talking about with the Allen head will adjust the tilt of the slide, meaning bringing the top of the slide in or out. Edited November 13, 2021 by Timaz996 Correct spelling
Analyte Posted November 13, 2021 Author Posted November 13, 2021 2 hours ago, Timaz996 said: The one midway in the arm is the bolt you’ll adjust to move that end of the slide out or in. The one you were talking about with the Allen head will adjust the tilt of the slide, meaning bringing the top of the slide in or out. Copy on the Allen head, it wasn't clear where he was adjusted but tilt isn't my issue. I may need to spray those with some penetrating oil a day or so before I mess with them if typically tight. How do I adjust the interior tighter to the wall? I guess loosen both nuts, but then what? Tim, thanks for all the help with my million questions. Shocking I'm unable to find a service document online that spells out what to do.
timaz996 Posted November 13, 2021 Posted November 13, 2021 Attached is the instructions for bleeding the slide but it will show you how to adjust it. Tim HWH Living Room Slde Bleeding VIP!!!!.pdf
Bill C Posted November 13, 2021 Posted November 13, 2021 I have this kind of slide, thanks for sharing this doc (for my future reference should I need it)
Analyte Posted November 14, 2021 Author Posted November 14, 2021 11 hours ago, Timaz996 said: Attached is the instructions for bleeding the slide but it will show you how to adjust it. Tim HWH Living Room Slde Bleeding VIP!!!!.pdf 25.74 kB · 6 downloads Thank you again sir!!
Wheelsnkeels Posted November 14, 2021 Posted November 14, 2021 We have the same coach and model, Be certain that the coach is leveled as your viewing this seal prior to adjustment. My experience is sometimes on uneven ground It sometimes has a gap and other times it does not.
Analyte Posted December 12, 2021 Author Posted December 12, 2021 Ok, with the help of the attachment above I'm now comfortable that the slide is adjusted out correctly. That said, I now need to tilt the inside room upper about 3/4 inch closer to the wall to better seal the top gasket. I've been searching for similar HWH documents, but I haven't found anything yet. I did find a post about someone adjusting the tilt via an access panel under the kitchen faucet, but I looked at mine and it doesn't appear my cabinet floor is removable unless I'm missing something. I did check the shoes under the cabinets and it doesn't appear those are an issue. Any thoughts on what I need to do? Thanks.
timaz996 Posted December 12, 2021 Posted December 12, 2021 That will be the tilt adjustment with the allen head screw. I think you tighten it to bring the top out against the seal. Tim
Analyte Posted December 12, 2021 Author Posted December 12, 2021 40 minutes ago, Timaz996 said: That will be the tilt adjustment with the allen head screw. I think you tighten it to bring the top out against the seal. Tim Where are these Allen head screws located? Thanks!
timaz996 Posted December 12, 2021 Posted December 12, 2021 11 minutes ago, Analyte said: Where are these Allen head screws located? Thanks! Your very first picture shows a large nut on the bottom of the arm. That is the lock nut for the allen head screw, Brake that nut loose and adjust it.
Analyte Posted December 12, 2021 Author Posted December 12, 2021 2 minutes ago, Timaz996 said: Your very first picture shows a large nut on the bottom of the arm. That is the lock nut for the allen head screw, Brake that nut loose and adjust it. Is the circled area the nut you're referring to? It's raining outside at the moment so I can't go look. And tighten it to bring the interior side closer to the interior wall?
timaz996 Posted December 12, 2021 Posted December 12, 2021 3 minutes ago, Analyte said: Is the circled area the nut you're referring to? It's raining outside at the moment so I can't go look. And tighten it to bring the interior side closer to the interior wall? I don't see a picture with a circle. It's the only nut on the bottom of the arm out on the end. It has dirty oil on it.
Analyte Posted December 12, 2021 Author Posted December 12, 2021 5 minutes ago, Timaz996 said: I don't see a picture with a circle. It's the only nut on the bottom of the arm out on the end. It has dirty oil on it. Here it is, forgot to attach it...
timaz996 Posted December 12, 2021 Posted December 12, 2021 Yes this is the nut. Brake it loose and adjust the allen screw about three turns in with the slide pulled in a couple inches then put it out all of the way. If I remember correctly the adjustment is opposite of what I thought it would be.
Analyte Posted December 12, 2021 Author Posted December 12, 2021 16 minutes ago, Timaz996 said: Yes this is the nut. Brake it loose and adjust the allen screw about three turns in with the slide pulled in a couple inches then put it out all of the way. If I remember correctly the adjustment is opposite of what I thought it would be. Got it, thank you so much. I didn't think about need to bring the slide in a bit to take the pressure off so thanks for that tip as well!
timaz996 Posted December 12, 2021 Posted December 12, 2021 Let us know how it goes when you get it done. Tim
Analyte Posted December 12, 2021 Author Posted December 12, 2021 13 minutes ago, Timaz996 said: Let us know how it goes when you get it done. Tim Will do!
