tomevansfl Posted November 14, 2021 Share Posted November 14, 2021 I have a 2001 Diplomat with carefree power main awning. It extends fine but the awning over the door doesn’t extend. I understood both opened at the same time. Is there a second switch? Where would I find it? What am I missing? Link to comment Share on other sites More sharing options...
Wrayj1 Posted November 14, 2021 Share Posted November 14, 2021 My '07 Holiday Rambler has separate control for the door awning, mine are on a panel at the left inside of the entry door. Link to comment Share on other sites More sharing options...
Jdw12345 Posted November 14, 2021 Share Posted November 14, 2021 Here’s a owner’s manual if you want one! https://www.monacocoach.com/resources/media/manuals/2001_Diplomat.pdf Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted November 14, 2021 Share Posted November 14, 2021 I have a 2001 diplomat. The main awning is power , the one over the door is a manual pull. Wonder if you might be missing the pull strap. Post a picture. Link to comment Share on other sites More sharing options...
tomevansfl Posted November 14, 2021 Author Share Posted November 14, 2021 16 hours ago, BobSchmeck said: I have a 2001 diplomat. The main awning is power , the one over the door is a manual pull. Wonder if you might be missing the pull strap. Post a picture. If I have a pull strap it is rolled up in the awning. It makes sense that it would be manual. The control panel for the main patio awning only has one button and a key switch. There are a series of three rocker switches. One says patio light and the another has a red symbol but it is worn/faded to the point I can’t tell what it does. I thought that might control the door awning but as far as I can tell it doesn’t seem to do anything. Any ideas what it’s for? My RV is in storage so I don’t have the option of photographing them for a few days. Link to comment Share on other sites More sharing options...
Wrayj1 Posted November 14, 2021 Share Posted November 14, 2021 The red one might be your battery disconnect switch, mine is on the same panel, by the front door, as the step cover, porch light, big awning etc. Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted November 14, 2021 Share Posted November 14, 2021 2 hours ago, tomevansfl said: If I have a pull strap it is rolled up in the awning. It makes sense that it would be manual. The control panel for the main patio awning only has one button and a key switch. There are a series of three rocker switches. One says patio light and the another has a red symbol but it is worn/faded to the point I can’t tell what it does. I thought that might control the door awning but as far as I can tell it doesn’t seem to do anything. Any ideas what it’s for? My RV is in storage so I don’t have the option of photographing them for a few days. Is this the setup that you have? Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted November 14, 2021 Share Posted November 14, 2021 Is this the setup you have? Link to comment Share on other sites More sharing options...
tomevansfl Posted November 15, 2021 Author Share Posted November 15, 2021 2 hours ago, BobSchmeck said: Is this the setup that you have? Yes! I don’t think I’ve tried the switch while there would be air in the system. I’ll try it the next time I have the system aired up. There is a step cover switch next to the co-pilot’s seat, though. Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted November 15, 2021 Share Posted November 15, 2021 1 hour ago, tomevansfl said: Yes! I don’t think I’ve tried the switch while there would be air in the system. I’ll try it the next time I have the system aired up. There is a step cover switch next to the co-pilot’s seat, though. The step cover needs air to operate. The entry step switch is for the lights on the side of the steps and a light underneath the outside mechanical steps. There's a step cover switch by the co-pilot & on the dash by the driver. Link to comment Share on other sites More sharing options...
tomevansfl Posted November 15, 2021 Author Share Posted November 15, 2021 Ok. The light fixtures next the steps don’t currently have bulbs in them. Link to comment Share on other sites More sharing options...
tcbrow Posted November 16, 2021 Share Posted November 16, 2021 On my 2001 Diplomat the step switch is used to stop the step (usually when extended) from retracting and extending every time the door is opened or closed. 1 Link to comment Share on other sites More sharing options...
tomevansfl Posted November 18, 2021 Author Share Posted November 18, 2021 On 11/15/2021 at 8:29 PM, tcbrow said: On my 2001 Diplomat the step switch is used to stop the step (usually when extended) from retracting and extending every time the door is opened or closed. I have my coach in the shop for another reason. I tried the button with the worn red surface. It is made differently from the photo. I had the door open with the exterior step extended and tried the switch...nothing, the step still retracted when I closed the door. I tried the switch in the other direction and still, nothing happened and the step retracted when I closed the door. Since my stepwell bulbs are missing, I think the switch might be to turn them on as you are entering the coach. Link to comment Share on other sites More sharing options...
