JohnnyDiesel Posted November 14, 2021 Share Posted November 14, 2021 (edited) I have a 2001 Executive with an ISM 500 in it. 26K miles on it. I bought it with the red warning light on. It drove ok but was obviously derating. I determined that the ambient air pressure sensor was bad and replaced it which shut off the warning light. I also replaced the temp sensor and the manifold pressure sensor. Today I took it for a shake down ride and the performance is notable improved. I noted that the boost pressure was pinning the 30 lbs gauge when I accelerated hard. I never noticed the boost pressure going past 25 before the sensor changes. Question, is it possible that I'm seeing an overboost condition? I know I have a VGT but I'm not sure how to diagnose turbo problems. I'm concerned that I'll trash the engine if I don't look further. Thanks in advance for your time and advice. Edited November 14, 2021 by JohnnyDiesel Link to comment Share on other sites More sharing options...
Dr4Film Posted November 14, 2021 Share Posted November 14, 2021 I thought the VGT's were introduced in later model coach's versus the 2001. Link to comment Share on other sites More sharing options...
JohnnyDiesel Posted November 14, 2021 Author Share Posted November 14, 2021 You may be correct. I just check the ESN on the Cummins Quickserv app and the turbo type says "wastegate". So maybe the wastegate isn't working correctly? Thoughts? Link to comment Share on other sites More sharing options...
vito.a Posted November 14, 2021 Share Posted November 14, 2021 The question is what exactly is the boost? Most of the ISM and ISX engines will pin a 30# gauge. But they are running only about 35psi. The ECU should program the fuel according to the air density and boost so it shouldn't hurt anything. If you want to play it safe install an EGT (exhaust gas temperature) gauge. Link to comment Share on other sites More sharing options...
JohnnyDiesel Posted November 14, 2021 Author Share Posted November 14, 2021 Thanks for your feedback. Much appreciated. John Link to comment Share on other sites More sharing options...
