moxy1962 Posted November 15, 2021 Share Posted November 15, 2021 Anyone have a fix for seat motors moving slow or not at all thanks Bill Link to comment Share on other sites More sharing options...
Paul Busch Posted November 15, 2021 Share Posted November 15, 2021 My 05 sig just needed the worm drive old dried grease cleaned up and new grease. After not being used it dried up and was like rock. Good luck paulb Link to comment Share on other sites More sharing options...
moxy1962 Posted November 15, 2021 Author Share Posted November 15, 2021 17 minutes ago, Paul Busch said: My 05 sig just needed the worm drive old dried grease cleaned up and new grease. After not being used it dried up and was like rock. Good luck paulb Thanks Psul, I assume you mean cable drive ? Link to comment Share on other sites More sharing options...
Paul Busch Posted November 15, 2021 Share Posted November 15, 2021 Sig seats have worm and gear drive motors. The one I had trouble with was the reclining worm drive. The gear was plugged with dried grease. I just cleaned the worm drive gears and re greased. Link to comment Share on other sites More sharing options...
moxy1962 Posted November 15, 2021 Author Share Posted November 15, 2021 Ok perfect thank you Link to comment Share on other sites More sharing options...
Paul Busch Posted November 15, 2021 Share Posted November 15, 2021 Good luck. Sure is a learning curve isn’t it? Link to comment Share on other sites More sharing options...
moxy1962 Posted November 15, 2021 Author Share Posted November 15, 2021 16 minutes ago, Paul Busch said: Good luck. Sure is a learning curve isn’t it? Once had this coach for 7 years now always something now, I’m becoming quite a expert Link to comment Share on other sites More sharing options...
Old Dog Posted November 15, 2021 Share Posted November 15, 2021 My passenger seat recline screw started gobbling up the Cashion material. Had to dig it all then worked fine. Wife weighs 110 lbs, no idea how that was possible. Spoke to the guy who runs the company that made the seats about a parts list and they don't have that info. He said they use what ever is available from the automotive market at the time to fill the orders as they get them. No blue prints or nothing. If something does fail then you'll have to pull it out and hope you can find a suitable replacement or exchange motors for a less vital function. Hope this helps Link to comment Share on other sites More sharing options...
Rikadoo Posted November 16, 2021 Share Posted November 16, 2021 Hey FYI my seats started moving slow so i sprayed all moving parts with Tri-Flo spray lube. From there i just added the procedure to my yearly maint program Link to comment Share on other sites More sharing options...
moxy1962 Posted November 16, 2021 Author Share Posted November 16, 2021 Ends up gears are stripped in forward and backwards so need new 6 wat assembly Link to comment Share on other sites More sharing options...
