Rikadoo Posted November 15, 2021 Share Posted November 15, 2021 So my observation is due to watching my voltage on a digital gauge that when the coach is connected to city power source the gauge shows 118 to 120 vac, pretty normal. However once I disconnect city power and engage my inverter then the volt gauge only shows 102 to 104 vac, my question, is that a issue with my inverter, or is it due to using a digital gauge? My inverter is a Xantec freedom semi-sine wave that appears to be originall and is operating with a fully charged battery bank with no load other that minimal parasitic draw from microwave clock. Link to comment Share on other sites More sharing options...
Tom Wallis Posted November 15, 2021 Share Posted November 15, 2021 (edited) I think the issue is with your inverter. A digital gauge should be able to read the inverter voltage accurately. 104 volts is pretty low and my not be good for some of your electric accesories. Edited November 15, 2021 by Tom Wallis Link to comment Share on other sites More sharing options...
Ivan K Posted November 15, 2021 Share Posted November 15, 2021 I'd say that your meter can't read the inverted AC voltage that isn't a perfect sine wave. In my case and with my meter, I get 96V reading while inverting. 1 Link to comment Share on other sites More sharing options...
dleeadkins Posted November 15, 2021 Share Posted November 15, 2021 This is what you will see with a modified sine wave inverter. Link to comment Share on other sites More sharing options...
waterskier_1 Posted November 15, 2021 Share Posted November 15, 2021 You need a true RMS reading AC voltmeter to accurately read the equivalent voltage with modified Sine Wave inverters. The general purpose AC voltmeter are designed for Pure Sine Wave applications only. You likely do not have an inverter problem. 2 Link to comment Share on other sites More sharing options...
jacwjames Posted November 15, 2021 Share Posted November 15, 2021 This is one of the things that got me in trouble back in Aug, I was reading low voltage through the inverter using a digital meter and had other problems so I assumed my inverter was bad. When I was testing the 120 volt side with the inverter unhooked I saw ohms across one of the leads so I thought I had a problem. Even called Xantrex and they said >>>Yup your inverter is bad. So I pulled the inverter and more testing. Then I called one of the Xantrex repair facilities near Nashville and told him the symptoms and he said the inverter was fine. Put it back in and then tested with my Klien digital meter and it showed 120 volt. Live and learn. Just something you have to keep buried in the back of your mind. Link to comment Share on other sites More sharing options...
cbr046 Posted November 16, 2021 Share Posted November 16, 2021 17 hours ago, jacwjames said: Put it back in and then tested with my Klien digital meter and it showed 120 volt. Makes me wonder what my Harbor Freight "free with purchase" DMM would read . . . . 🤣 - bob Link to comment Share on other sites More sharing options...
Rikadoo Posted November 16, 2021 Author Share Posted November 16, 2021 Well now i have something else to keep me busy, i never thought to use my DVOM i just was thinking cause the plug in gauge was digital it would read ANY AC voltage properly, I have a couple DVOMs and actually i have one that does read RMS. Thank you everyone for your Input an help. Link to comment Share on other sites More sharing options...
