moxy1962 Posted November 20, 2021 Share Posted November 20, 2021 With aqua hot on and rads working voltage dropped to 12.52 volts after 30 minutes, will continue to monitor just curious if others have any comparisons Link to comment Share on other sites More sharing options...
waterskier_1 Posted November 20, 2021 Share Posted November 20, 2021 What brand & type battery? Lithium vs lead acid are very different. So are manufactures. And the actual load will Mahe a difference too. Link to comment Share on other sites More sharing options...
moxy1962 Posted November 20, 2021 Author Share Posted November 20, 2021 GC2 230 amp lead acid 6 volt x4 Link to comment Share on other sites More sharing options...
96 EVO Posted November 20, 2021 Share Posted November 20, 2021 Ambient temp will also make a difference. If you have lead acid batteries, 12.5v is practically fully charged in freezing weather. Link to comment Share on other sites More sharing options...
moxy1962 Posted November 20, 2021 Author Share Posted November 20, 2021 3 minutes ago, 96 EVO said: Ambient temp will also make a difference. If you have lead acid batteries, 12.5v is practically fully charged in freezing weather. Back up to 12.65 v with just rads and circ pumps running fur 1 hour Link to comment Share on other sites More sharing options...
96 EVO Posted November 20, 2021 Share Posted November 20, 2021 Hmmm! I've never noticed my burner motor having a lot of draw on my batteries. Link to comment Share on other sites More sharing options...
moxy1962 Posted November 20, 2021 Author Share Posted November 20, 2021 3 minutes ago, 96 EVO said: Hmmm! I've never noticed my burner motor having a lot of draw on my batteries. Pretty big motor lol Link to comment Share on other sites More sharing options...
96 EVO Posted November 20, 2021 Share Posted November 20, 2021 Running the system at home while plugged into 30A shore, I generally see 17DC amps from the charger to the batteries with the whole system running. After the burner shuts down, and purge ends, drops to 3DC amps for just the pumps and heat exchanger fans. Don't know how accurate the Magnum inverter meter is. Link to comment Share on other sites More sharing options...
waterskier_1 Posted November 20, 2021 Share Posted November 20, 2021 2 hours ago, 96 EVO said: Hmmm! I've never noticed my burner motor having a lot of draw on my batteries. It's not just the burner blower motor, but the fuel pump, solenoids, and other things that draw power. The Aquahot manual states that the main Aquahot unit draws 60 Watts, the Circulation Pumps draw 21 Watts each, and the Cozys (Registers) draw 6.25 Watts each. 2 hours ago, moxy1962 said: GC2 230 amp lead acid 6 volt x4 Trojan lead acid batteries show that fully charged, no load, after letting the surface charge dissipate, is 12.74 Volts. You voltage, if NOT under load, would indicate just over 80% SOC, but since it is under unspecified load, the SOC would be higher. Link to comment Share on other sites More sharing options...
moxy1962 Posted November 20, 2021 Author Share Posted November 20, 2021 50 minutes ago, waterskier_1 said: It's not just the burner blower motor, but the fuel pump, solenoids, and other things that draw power. The Aquahot manual states that the main Aquahot unit draws 60 Watts, the Circulation Pumps draw 21 Watts each, and the Cozys (Registers) draw 6.25 Watts each. Trojan lead acid batteries show that fully charged, no load, after letting the surface charge dissipate, is 12.74 Volts. You voltage, if NOT under load, would indicate just over 80% SOC, but since it is under unspecified load, the SOC would be higher. Been running for hours and still at 12.5 volts Link to comment Share on other sites More sharing options...
