moxy1962 Posted November 23, 2021 Share Posted November 23, 2021 Anyone know the location of the passenger side power seat fuse. my drawing as so blurry I cant read most of the fuses Thanks Bill, Link to comment Share on other sites More sharing options...
Dr4Film Posted November 23, 2021 Share Posted November 23, 2021 Bill, The seats in my 2002 Windsor have no fuses but rather two circuit breakers located in the Front Run Bay under the driver's window. I would check the power supply wires under the seat to see if the connector came loose or the wires have been compromised. Link to comment Share on other sites More sharing options...
Ivan K Posted November 24, 2021 Share Posted November 24, 2021 My Villa seats have one fuse each in the harness under the seat. Couple times the harness connector got pulled open too. Depends what you got. Link to comment Share on other sites More sharing options...
Notn2bars Posted November 24, 2021 Share Posted November 24, 2021 When my driver seat quit working, it wasn't the fuse or relay. One of the spade connectors had come loose inside the plastic loom hidden under the velcro and vinyl cover. Link to comment Share on other sites More sharing options...
James Weir Posted November 24, 2021 Share Posted November 24, 2021 I have a 2007 Dynasty with tag and the fuses for the seats are located in the front run box. There are circuit breakers for the seats in addition to the fuses and on my rig they are located in the front run box at the top. I had an issue with the passenger seat and it turned out to be the circuit breaker being badly corroded. I've attached a schematic for the seat. Jim 07 Dynasty Schematic - Seats (1).pdf Link to comment Share on other sites More sharing options...
Bill C Posted November 25, 2021 Share Posted November 25, 2021 I have a 2001 Dynasty with tag, here are the pics of the fuse panel located outside below the drivers seat. As best I can tell the seat (not sure if both) is a circuit breaker located on the left side of the compartment, mid way up. There are four self resting circuit breakers, the power seat is the second from the top. Hope this helps Bill Link to comment Share on other sites More sharing options...
moxy1962 Posted November 25, 2021 Author Share Posted November 25, 2021 5 minutes ago, Corkman said: I have a 2001 Dynasty with tag, here are the pics of the fuse panel located outside below the drivers seat. As best I can tell the seat (not sure if both) is a circuit breaker located on the left side of the compartment, mid way up. There are four self resting circuit breakers, the power seat is the second from the top. Hope this helps Bill Perfect thank you Link to comment Share on other sites More sharing options...
moxy1962 Posted November 25, 2021 Author Share Posted November 25, 2021 6 hours ago, moxy1962 said: Perfect thank you all fixed, power wise, transmission is still shot for forward and reverse on passenger seat, looking for 6 way power seat carriage, my coach has Villa seats if anyone has a lead, over $500.00 US for replacement. Link to comment Share on other sites More sharing options...
Paul J A Posted November 26, 2021 Share Posted November 26, 2021 19 hours ago, moxy1962 said: all fixed, power wise, transmission is still shot for forward and reverse on passenger seat, looking for 6 way power seat carriage, my coach has Villa seats if anyone has a lead, over $500.00 US for replacement. RV Parts & Salvage Yards https://bontragers.com ; http://www.paramountautobody.com/reno-nevada-used-rv... www.rvdoctorgeorge.com https://colawrvsalvage.com/, https://www.veurinksrv.com/ https://www.rvyard.com/ findmyrvparts.com Link to comment Share on other sites More sharing options...
