Bob Stevens Posted November 26, 2021 Share Posted November 26, 2021 No 12 volt lighting, bath fan, thermostat battery is good 12v+. Have power to ignition Link to comment Share on other sites More sharing options...
vito.a Posted November 26, 2021 Share Posted November 26, 2021 What model coach do you have? Most motor homes have two 12v systems. One runs the chassis/engine. The other runs the house and through the inverter some of the 120v system. Use a volt/ohm meter and test all the batteries, both house and chassis. Make sure the salesman switch near the entry is on. Make sure both battery cutoff switches are on. Link to comment Share on other sites More sharing options...
klcdenver Posted November 26, 2021 Share Posted November 26, 2021 Check your DC fuses, usually located in your bedroom closet Link to comment Share on other sites More sharing options...
Bob Stevens Posted November 26, 2021 Author Share Posted November 26, 2021 1998 Windsor no slides no power to the bedroom fuse box Both batteries good. salesman switch is good Bad solenoid after salesman switch. I wired around it for now Link to comment Share on other sites More sharing options...
woodylmiller Posted November 26, 2021 Share Posted November 26, 2021 Jump the salesman relay and check. It was the problem when we had that problem. A latching relay in the rear run box next to the big boy is where mine is located. Still have it jumped since we never use the salesman switch and they mounted that relay in a really tough spot to get to. Good luck. Woody Miller 09 Dynasty Link to comment Share on other sites More sharing options...
Bob Stevens Posted November 26, 2021 Author Share Posted November 26, 2021 Mine was the solenoid. Jumped it. All better now. Link to comment Share on other sites More sharing options...
