slaterson1 Posted December 2, 2021 Share Posted December 2, 2021 Hey everyone, I am having a fridge problem, naturally. We have a Norcold 1200, 4-door fridge, it has stopped cooling and there is no power going to the control panel. I have consulted my wiring diagram book and looked all over this thing trying to find a fuse and haven't been able to find it. Can anyone point me in the right direction? It's a 2004 Executive 42SBW if that makes any difference. Thanks! Link to comment Share on other sites More sharing options...
Jim Byrd Posted December 2, 2021 Share Posted December 2, 2021 Not sure about the location on your rig, the 5 amp fuse is located in outside compartment under the drivers seat on my Holiday Rambler Endeavor, Link to comment Share on other sites More sharing options...
slaterson1 Posted December 2, 2021 Author Share Posted December 2, 2021 8 minutes ago, Jim Byrd said: Not sure about the location on your rig, the 5 amp fuse is located in outside compartment under the drivers seat on my Holiday Rambler Endeavor, I looked there and don't see anything other than mostly chassis fuses, nothing that explicitly says refer at least. Link to comment Share on other sites More sharing options...
nvrtoofast Posted December 2, 2021 Share Posted December 2, 2021 Does your fridge not run off of the house breaker panel in the bedroom? That is where mine comes from Link to comment Share on other sites More sharing options...
Jim Byrd Posted December 2, 2021 Share Posted December 2, 2021 I had difficulty in finding it on mine. it was listed on the fuse index inside the cover. Link to comment Share on other sites More sharing options...
slaterson1 Posted December 2, 2021 Author Share Posted December 2, 2021 13 minutes ago, nvrtoofast said: Does your fridge not run off of the house breaker panel in the bedroom? That is where mine comes from I can't tell really, there is no label for the refrigerator, the only thing close would be the galley lights/rope lights. I pulled the fuse panel off the wall and all the wires are white, not the color shown on the labels. Either way there are no blown fuses there, I pulled and checked them all. Maybe I'm just slow or missing something. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 2, 2021 Share Posted December 2, 2021 (edited) Dane, My 2002 Windsor has one fuse located in an overhead cabinet in the bedroom on a House fuse panel. Then on the backside of the fridge itself there is a control board which has two fuses, one tubular Glass Fuse and one spade type 5 amp fuse. I have forgotten what thay are for but you may want to check those also. Rad arrows point to the two fuses on the control board. Edited December 2, 2021 by Dr4Film Added two more photos 1 Link to comment Share on other sites More sharing options...
slaterson1 Posted December 2, 2021 Author Share Posted December 2, 2021 8 minutes ago, Dr4Film said: Dane, My 2002 Windsor has one fuse located in an overhead cabinet in the bedroom on a House fuse panel. Then on the backside of the fridge itself there is a control board which has two fuses, one tubular Glass Fuse and one spade type 5 amp fuse. I have forgotten what thay are for but you may want to check those also. Rad arrows point to the two fuses on the control board. I'm going to check the board on the back of the fridge right now, problem is I'm not getting 12v to the connection feeding the board, which is why I suspect a fuse back upstream somewhere, just can't find it. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 2, 2021 Share Posted December 2, 2021 Dane, Does your "Black Box" have a red light lit up on it? This it the Norcold "high temp" protection device that was part of a recall back in the day when they were having so many fridge fires destroying peoples coaches. Link to comment Share on other sites More sharing options...
Donflem Posted December 2, 2021 Share Posted December 2, 2021 I was going to say the same thing Richard. I wonder if he just needs to run a magnet over the black box to reset it, every time I wash my couch I have to go out and reset the refrigerator with a magnet. I’ve seen posts about how to do it but it’s pretty easy just go stick a magnet on it until you hear it click. I pray that’s all it is good luck. Don Link to comment Share on other sites More sharing options...
jacwjames Posted December 2, 2021 Share Posted December 2, 2021 I had the same problem and got by resetting the system with a magnet until one day after resetting it kicked again and I noticed a yellow dust under the fridge. My system failed but fortunately I didn't have a fire. I've since replaced with a Samsung, top of the list as one of my modes on my coach. Link to comment Share on other sites More sharing options...
Jim Byrd Posted December 2, 2021 Share Posted December 2, 2021 1 hour ago, slaterson1 said: I can't tell really, there is no label for the refrigerator, the only thing close would be the galley lights/rope lights. I pulled the fuse panel off the wall and all the wires are white, not the color shown on the labels. Either way there are no blown fuses there, I pulled and checked them all. Maybe I'm just slow or missing something. My refrigerator 12v DC is connected to the CHASSIS battery. you need to look at the chassis fuse list that can be found on the inside of the cover located in the compartment under the drivers seat. Link to comment Share on other sites More sharing options...
slaterson1 Posted December 2, 2021 Author Share Posted December 2, 2021 So the whole refrigerator is dead, nothing showing on the inside panel, no power coming in on the 12v wire feeding the board on the back of the fridge, no fuses blown on the board, no lights lit up, no nothing. There is no fuse labeled for the refrigerator in the front run box under the drivers seat, nor the rear run box in the engine compartment. The wire is not shown or labeled anywhere in any of the probably 100 pages of wiring diagrams. This makes no sense. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 2, 2021 Share Posted December 2, 2021 No comment in regards to the high temp black box? What is the status of that box?? Link to comment Share on other sites More sharing options...
Ivan K Posted December 2, 2021 Share Posted December 2, 2021 Our coach is years older but there still might be some similarity. Our Refer is on a breaker in D side RRB. Link to comment Share on other sites More sharing options...
slaterson1 Posted December 2, 2021 Author Share Posted December 2, 2021 1 hour ago, Dr4Film said: No comment in regards to the high temp black box? What is the status of that box?? High temp box is in place with no lights lit. There is no power coming to the 12v wire that is feeding it. 49 minutes ago, Ivan K said: Our coach is years older but there still might be some similarity. Our Refer is on a breaker in D side RRB. I looked in the rear run box but I still don't see a spot marked refer. I am at a loss, I refuse to believe that there isn't a marked and accessible fuse for the refrigerator on this coach. So weird. Link to comment Share on other sites More sharing options...
Ivan K Posted December 2, 2021 Share Posted December 2, 2021 (edited) Could try a tone tracer then. If there is a burned out fuse, the wire would be isolated and tracing should work. Still a quessing game as far as it's location. Edited December 2, 2021 by Ivan K Link to comment Share on other sites More sharing options...
Tom Wallis Posted December 3, 2021 Share Posted December 3, 2021 For what it's worth, I had to replace a thermal fuse on my son's motorhome. His refrigerator was a Dometic not a a Norcold. When it went out the whole refrigerator went completely dead. It was on the back near the burner. However, if there's no power at all to the unit, you most likely have a different problem. Link to comment Share on other sites More sharing options...
MrAmbassador Posted December 3, 2021 Share Posted December 3, 2021 Driver side outside compartment front there is a black fuse box. Look for fuse 5-67 it should be a 5 amp fuse. This was the problem for me. I got tired of it blowing and went with a residential refer. Hope this helps. Link to comment Share on other sites More sharing options...
Bootlegger 659 Posted December 3, 2021 Share Posted December 3, 2021 You may have fixed your problem, but on my 05 diplomate my 12 volt fused feed comes from a control board located on the back of the fridge. Go outside to the refer access panel, open and inside there is a black plastic cover (box). Take that cover off and you will see the fuse. Real treat to get to. Mine is located in the upper left behind the access panel. Link to comment Share on other sites More sharing options...
johncvandoren@gmail.com Posted December 3, 2021 Share Posted December 3, 2021 20 hours ago, slaterson1 said: So the whole refrigerator is dead, nothing showing on the inside panel, no power coming in on the 12v wire feeding the board on the back of the fridge, no fuses blown on the board, no lights lit up, no nothing. There is no fuse labeled for the refrigerator in the front run box under the drivers seat, nor the rear run box in the engine compartment. The wire is not shown or labeled anywhere in any of the probably 100 pages of wiring diagrams. This makes no sense. Is your fridge in a slideout? After finding and replacing all three fuses mentioned above—to no avail—I found a loose Molex connection where it transitions from the chassis to the slide. It was under the floor of the cabinets behind the dining room table. Good luck! Link to comment Share on other sites More sharing options...
slaterson1 Posted December 4, 2021 Author Share Posted December 4, 2021 On 12/2/2021 at 10:50 AM, Dr4Film said: Dane, My 2002 Windsor has one fuse located in an overhead cabinet in the bedroom on a House fuse panel. Then on the backside of the fridge itself there is a control board which has two fuses, one tubular Glass Fuse and one spade type 5 amp fuse. I have forgotten what thay are for but you may want to check those also. Rad arrows point to the two fuses on the control board. Sorry it's taken me a bit to update this thread, but the long and short of it is the fridge works again. Dr4Film was the winner, when I pulled the cover off the control board the 5A fuse was blown, I replaced it and all was good. I also located the main fuse in the rear run box, it was in the #5 fuse panel along with the AquaHot fuse, the label just had some gunk on it and was hard to read. So anyway, thanks to everyone, I'm new to pushers and am learning a lot thanks to this forum! Link to comment Share on other sites More sharing options...
slaterson1 Posted December 4, 2021 Author Share Posted December 4, 2021 On 12/3/2021 at 11:39 AM, Bootlegger 659 said: You may have fixed your problem, but on my 05 diplomate my 12 volt fused feed comes from a control board located on the back of the fridge. Go outside to the refer access panel, open and inside there is a black plastic cover (box). Take that cover off and you will see the fuse. Real treat to get to. Mine is located in the upper left behind the access panel. I did fix it by doing exactly this. Mine wasn't too bad to access but yes, I can see where if the access was any smaller it could be tough. Thanks for the tip. Link to comment Share on other sites More sharing options...
jacwjames Posted December 5, 2021 Share Posted December 5, 2021 2 hours ago, slaterson1 said: I did fix it by doing exactly this. Mine wasn't too bad to access but yes, I can see where if the access was any smaller it could be tough. Thanks for the tip. Did you determine whether you had the recall done on your fridge where they install a black box the detects high temps in the flue and if it senses high temps shuts down the fridge? Link to comment Share on other sites More sharing options...
slaterson1 Posted December 5, 2021 Author Share Posted December 5, 2021 14 hours ago, jacwjames said: Did you determine whether you had the recall done on your fridge where they install a black box the detects high temps in the flue and if it senses high temps shuts down the fridge? Yes, the recall has been done, it has the box and the high temp cutoff sensor in the flue. Link to comment Share on other sites More sharing options...
