birdshill123 Posted December 2, 2021 Share Posted December 2, 2021 I am having trouble with my air horn. 08 Dynasty. I cannot find a sepecific fuse for the horn. Board f8 has a marker for a 10 amp fuse but there is a 6 amp auto reset in that position. There is supposed to be a relay as well but could not find one. I ran power to the Hadley air solenoid and the horn worked. I removed the wheel cover and crossed 2 wires. Nothing. I did the test on J2.1. Nothing. My controller is a series 2 sm211 Unless I find a fuse I am assuming that the controller is bad. I did get some of that info on IRV2. I hate to buy a controller and find out it still does not work. The controller is obsolete but a few are available at over $300 to over $400. I can buy a sm213 module but it has extra connections. Don't know if it can be substituted. Any help appreciated Link to comment Share on other sites More sharing options...
DavidL Posted December 2, 2021 Share Posted December 2, 2021 See if you can find an electrical schematic on the controller wiring. Then get a friend who is electrical savvy to help you out. Does anything work on the controller board? If so, then good chance a new one isn't needed. Possibly a new relay, a new breaker, a wire soldered, but need to get someone who understands diagnostics to break the system down, test the pieces to determine fault. 1 Link to comment Share on other sites More sharing options...
tmw188 Posted December 2, 2021 Share Posted December 2, 2021 Agree with DavidL Link to comment Share on other sites More sharing options...
jacwjames Posted December 3, 2021 Share Posted December 3, 2021 2 hours ago, birdshill123 said: I am having trouble with my air horn. 08 Dynasty. I cannot find a sepecific fuse for the horn. Board f8 has a marker for a 10 amp fuse but there is a 6 amp auto reset in that position. There is supposed to be a relay as well but could not find one. I ran power to the Hadley air solenoid and the horn worked. I removed the wheel cover and crossed 2 wires. Nothing. I did the test on J2.1. Nothing. My controller is a series 2 sm211 Unless I find a fuse I am assuming that the controller is bad. I did get some of that info on IRV2. I hate to buy a controller and find out it still does not work. The controller is obsolete but a few are available at over $300 to over $400. I can buy a sm213 module but it has extra connections. Don't know if it can be substituted. Any help appreciated Check directly with VIP smartwheel, as I remember they sell them for ~$200 Link to comment Share on other sites More sharing options...
birdshill123 Posted December 3, 2021 Author Share Posted December 3, 2021 I will contact the company that now owns Samrtwheel. Thanks Link to comment Share on other sites More sharing options...
Trinidaddave Posted December 3, 2021 Share Posted December 3, 2021 For under $20 you can purchase a tone generator to trace the path of the circuit. It’s not a high quality, but works well when you do not know how your circuits route. Link to comment Share on other sites More sharing options...
rpasetto Posted December 3, 2021 Share Posted December 3, 2021 I recall similar symptoms a year+ ago... horn, then wipers went flaky. The first thing I did was replace the smartwheel controller; easiest to do. Then I replaced the clockspring which solved it. Link to comment Share on other sites More sharing options...
Ivylog Posted December 3, 2021 Share Posted December 3, 2021 Using the troubleshooting guide below, 2 people can diagnose the various functions. https://www.rvtechlibrary.com/electronics/SmartWheelTroubleshooting.pdf Link to comment Share on other sites More sharing options...
birdshill123 Posted December 3, 2021 Author Share Posted December 3, 2021 I called the present owners of the smart wheel. It appears they are now the 3rd owner. They no longer have any tech support. But the nice lady told me how to find the troubleshooting for my version. The controller failed the test. Everything works except the horn. I still wonder if there is a hidden fuse or relay somewhere. A tone generator wont help as the signal goes into the controller. There is no voltage at the solenoid when you apply the horn. But hook the solenoid to 12 volts and the horn works. I suppose it could be the clock spring but that is beyond my technical abilities. Of course there are no units available due to supply chain problems. But she said they should have everything in January and if I place an order they will build a controller. You can tell the units are designed by geeky engineers as are the diagnostic functions. The Dynasty is not going anywhere until April. If It is not functioning by then I will wire in a horn button! Link to comment Share on other sites More sharing options...
Ivylog Posted December 3, 2021 Share Posted December 3, 2021 (edited) The smart wheel is a multiplex system… only 2 wires from the steering wheel. Since other functions work, it’s not a bad clock spring. I would run a fused 12V to the solenoid assuming you are getting a signal to the solenoid, if you cannot find a blown fuse. Hopefully someone who has been down this road will chime in to its location. The more I learn about a system the better off I’ll be SO, I looked into the troubleshooting gide I posted above and found the following: HORN TEST - Connect the low current test light between a +12Vdc source and J2.1 (Horn output) on the Master. Press the HORN bar on the Steering Wheel and the test light should light. If it doesn't, the Horn output on the Master is damaged (replace the Master). Edited December 3, 2021 by Ivylog Link to comment Share on other sites More sharing options...
birdshill123 Posted December 4, 2021 Author Share Posted December 4, 2021 Ivylog. I did that test and it failed. I left everything connected on the controller and forced the point on my test light into the connector. Nothing. Then I stripped the wire j2.1. Still nothing. I wonder if there is some way to bypass the controller and still use the existing horn "button" on the wheel. Hypoxia has been helping me on the other forum. He suggested the same diagnostic. I do not have a 10 amp fuse marked horn. But there is a 6 amp auto reset fuse on board 8. I checked every fuse in the front run bay. All are good. The relays on that board are all soldered. I do not know where to find the horn relay. Small problem but frustrating. Thanks for your help. Link to comment Share on other sites More sharing options...
