GNRACN Posted December 4, 2021 Share Posted December 4, 2021 Recently replaced under sink or galley blower fan motor as previous one burned up when we were not at home. The switch and blower work fine as tested with aux. power. I have no power on the green wire to the switch and I can't locate the source of that wire in the Multiplex panel. I have removed and checked the five relays and they all switch on off as they should. Fuse is good on circuit marked under cab galley blower in the multiplex. Have spoke to aqua-hot and they tell me that blower for galley sink blower only is powered by the coach electrical system because of high current draw is to much for the aqua-hot panel. When the motor burned up I'm sure it would have tripped a fuse or relay because it locked the motor up tight. I have down loaded the files from this site plus I have purchased the 06 Dynasty electrical diagrams. It's bailed me out several times, but not this one. Anyone with any ideas or thoughts would certainly be appreciated! HELP Link to comment Share on other sites More sharing options...
jcavataio5255 Posted December 5, 2021 Share Posted December 5, 2021 You might want to check around your Aqua Hot control panel? My schematic is a 2005 version so it may not be the same as yours? but in the 05 version it appears there’s a fuse that powers the relay that send power to that blower? And if the blower motor seized, it probably would blow that fuse? John C Link to comment Share on other sites More sharing options...
GNRACN Posted December 7, 2021 Author Share Posted December 7, 2021 Problem solved! Thank you so much for the picture and info. Mine was not located on the back of the board but it got me to the right pew. Traced the wires up to wet bay ceiling. Cut a few tie wraps, spread some wires and there it was right over Aqua-Hot pumps, fuse holder and relay. Fuse was blown! Again thank you for reply! Link to comment Share on other sites More sharing options...
