Joelsheriff Posted December 5, 2021 Share Posted December 5, 2021 I'm going to do some welding under my bed in my 07 Diplomat. Metal holding slide broke and top of bed slide is flopping back and forth opening and closing. I remember someone saying to disconnect from shore power and turn off main power switches (big red ones in power bay) what else do I have to be cautious with please. TIA Joel Link to comment Share on other sites More sharing options...
JohnnyDiesel Posted December 6, 2021 Share Posted December 6, 2021 Disconnect batteries at their terminals. Shutting off main disconnect doesn't kill all power. I also recommend unplugging engine and transmission ECMs to isolate them from voltage spikes. Link to comment Share on other sites More sharing options...
DavidL Posted December 6, 2021 Share Posted December 6, 2021 Is the part you are welding connected to the chassis? Or is the bed frame independent? If independent...just make sure your welding ground is close to the spot you are welding on clean metal. Ensure weld splatter won't catch anything on fire. Weld to your heart's content. If electrically connected to the chassis...then all power off, batteries disconnected and expensive ECUs ideally unplugged like JohnnyDiesel states. Link to comment Share on other sites More sharing options...
Joelsheriff Posted December 6, 2021 Author Share Posted December 6, 2021 The bed frame and flooring is not connected to the frame but the rollers for the slide are right there. The piece being welded is attached to the floor and slide frame. Link to comment Share on other sites More sharing options...
bunlacken Posted December 6, 2021 Share Posted December 6, 2021 Cover everything within spark distance with wet towel's or a sbstitute (plastic underneath the towel) to prevent burn marks from slag sparks if you are doing arc, if torch welding heated area will be bigger but the same care will work. Steady hand will make a great job. Link to comment Share on other sites More sharing options...
