Duanebalogh Posted December 9, 2021 Posted December 9, 2021 We have our 2006 excetive Scandia and we have it plug in but on the dash monitor it reads no A/C detected but we know we have power. Could it be the monitor not reading it. Thank you
vito.a Posted December 9, 2021 Posted December 9, 2021 Is it plugged into a 50 amp RV pedestal? I assume by dash monitor you mean the Aladdin system? Check your Magnum inverter remote to see if it is charging your batteries and then try one of your heat pumps or A/C units to check your input power. Then try running your generator to see if the Aladdin display shows A/C input.
Duanebalogh Posted December 9, 2021 Author Posted December 9, 2021 We did what you said but the "no a/c power" still comes on. Checked everything, could it be a bad monitor.? Our surge guard is on cause the lites are red
vito.a Posted December 9, 2021 Posted December 9, 2021 Did your Aladdin ever show in coming AC power? Ours shows each AC leg separately with volts and amps. Unfortunately the Aladdin system is no longer supported. You could try looking for a bad connection.
Ivylog Posted December 9, 2021 Posted December 9, 2021 Hopefully it’s not a transfer switch problem…the two sensors that feed the monitor are in it. Switching to generator power will not make a difference as the sensors are on the output cables.
Chuck B 2004 Windsor Posted December 10, 2021 Posted December 10, 2021 Why do we have 2 threads going on the same subject?
Duanebalogh Posted December 10, 2021 Author Posted December 10, 2021 INo it never did show so we'llook for a bad connection and if we can't find it then we know it's the Aladin, thank you for your help
