Mi Bill Posted December 20, 2021 Share Posted December 20, 2021 We have a 2009 Dynasty Regal IV. The Thinlite 62A two bulb florescent patio light died. I bought a florescent to LED conversion kit from Camping World. I took the dead ballast out and wired directly. When the switch is off, I still get a low level of light. What did I do wrong? Thank you Bill Michigan Link to comment Share on other sites More sharing options...
MrAmbassador Posted December 21, 2021 Share Posted December 21, 2021 I am not sure what the kit consists of, but there appears to be some voltage when switch is turned off. If you have a multimeter check to see if you have some amount of voltage on your red and black wire. If your red wire has voltage, then your switch has a leak or there are some wires melted together from the switch to the lights. Hope this helps. Link to comment Share on other sites More sharing options...
Ivan K Posted December 21, 2021 Share Posted December 21, 2021 Going through a switch with indicator light possibly? 1 Link to comment Share on other sites More sharing options...
granvillebarker Posted December 21, 2021 Share Posted December 21, 2021 (edited) I have some leds that glow for a little bit after being cut off. Is it still visble after some time? I recently converted one of those but I just got a roll of LEDs and installed them. They are peel and stick with two wires on the end red / black. Edited December 21, 2021 by granvillebarker Typo Link to comment Share on other sites More sharing options...
DrDon4u Posted December 21, 2021 Share Posted December 21, 2021 I switched my docking to LED and they do the same thing, it has to do with the Multiplexer DON'T WORRY ABOUT IT!!! Treat it as a night light. Link to comment Share on other sites More sharing options...
Ivylog Posted December 21, 2021 Share Posted December 21, 2021 13 hours ago, granvillebarker said: I recently converted one of those but I just got a roll of LEDs and installed them I hope you have better luck with the led strips than I have. Multiple chips stop working and within less than 100 hours the remaining ones dim. Have replaced several used as night lights under bathroom cabinet. Instead of using a strip under the upper kitchen cabinets, I installed six 48 chip voltage regulated panels instead. Not as nice looking as a strip, but in 3 years, with a lot of use, every chip out of 576 are still working. Guarantee if I’d used a strip, that would not be true. Link to comment Share on other sites More sharing options...
