Bill C Posted December 23, 2021 Posted December 23, 2021 I have a 2002 Monaco Dynasty. Does anyone know where I can get a replacement Outside door/luggage door handle? Here is a pic of mine. Thanks, Bill
cbr046 Posted December 23, 2021 Posted December 23, 2021 I repaired mine . . . . I believe I drilled through the pivot point and inserted a bolt from the backside. If you're handy try that. - bob
Old Dog Posted December 23, 2021 Posted December 23, 2021 Most of them are made by Trimark, go to Trimarkcorp.com. and you should be able to find a match. Be careful because some come as right and left then you have the issue of matching the lock core to the existing key (I had three different keys when I bought my coach). Hope this helps 1
cbr046 Posted December 23, 2021 Posted December 23, 2021 I ran across this in another search. Look at the photos ONLY if you have a strong stomach https://rvexteriorbodypanels.visonerv.com/cgi-bin/welcome.pl? You can probably match your exact color by finding your model & year. - bob
Chuck B 2004 Windsor Posted December 23, 2021 Posted December 23, 2021 Down load the parts list for several options
Gary Cole Posted December 23, 2021 Posted December 23, 2021 (edited) The door handles are most always available on Ebay. If you are lucky in the color you need. Chrome is a good choice if not. Be aware that picking the Trimark locks and rekeying them is not possible according to the local locksmith. He spent 3 or 4 days playing around with one before conceding defeat. Edited December 23, 2021 by Gary Cole 1
Old Dog Posted December 23, 2021 Posted December 23, 2021 Trimark sells the core removal tool and will sell locks to match the key or reuse the existing core . Not cheap but can be done, just depends on how much you want to spend to have the same key.
Gary Cole Posted December 24, 2021 Posted December 24, 2021 (edited) That's good info Don. After replacing 4 broken locks I have decided to go lockless so that a next time does not happen. Other than the inverter bay and the battery bay I don't keep anything in the bays that is worth the effort and cost of replacing the broken handles. They can have the fishing rods, bait, firewood, and lawn furniture if they need it that badly. Most of the culprits probably can't spell inverter and certainly aren't interested in packing a 120 lb 8D battery some distance and over a fence . So I'm thinking I might be OK there.😀 Edited December 24, 2021 by Gary Cole 2
Bill C Posted December 25, 2021 Author Posted December 25, 2021 On 12/23/2021 at 9:58 AM, cbr046 said: I repaired mine . . . . I believe I drilled through the pivot point and inserted a bolt from the backside. If you're handy try that. - bob Good idea Bob, I was thinking the same thing. Unfortunately, I have to drill out all the rivets on the inside of the door to get to the latch, but It's still an option I am planning to try.
Bill C Posted December 25, 2021 Author Posted December 25, 2021 Thanks for the suggestions everyone, I should be able to find what I need at one of these web sites.
PatrickJames Posted April 28, 2022 Posted April 28, 2022 If i were at your place i would contact a local locksmith for that work.
SanbornNoah Posted February 25, 2023 Posted February 25, 2023 Door handles are easy to replace, take out the older bolts and install the door handle by putting new bolts into it. There is no need to contact any locksmith for that work.
