Radar22 Posted December 27, 2021 Share Posted December 27, 2021 Does anybody know why this light comes on the dash. Just had coached checked for alternator issues and possibly a parasitic draw. All checked out Ok. thanks Link to comment Share on other sites More sharing options...
vito.a Posted December 27, 2021 Share Posted December 27, 2021 Are you plugged into shore power or running the generator? Link to comment Share on other sites More sharing options...
Jim Byrd Posted December 28, 2021 Share Posted December 28, 2021 Not unusual if you have second charging source connected to the chassis batteries when you engine is running, Jim Link to comment Share on other sites More sharing options...
redstickbill Posted December 28, 2021 Share Posted December 28, 2021 I had the light come on after an alternator repair, problem was a 5 amp fuse in the wiring close to the alternator. Bill B (that problem was with a 2004 Endeavor) Link to comment Share on other sites More sharing options...
Larry Maida Posted December 28, 2021 Share Posted December 28, 2021 Quote My light will blink if batteries are fully charged and alternator is pushing 13.5 or 14 amps. I turn on my marker lights and it stops blinking. If I leave markers on for about an hour it is corrected. Link to comment Share on other sites More sharing options...
Michael Powell Posted December 28, 2021 Share Posted December 28, 2021 If you turn tour headlights on and it goes off. There is a kit that uses a relay that fixes that... I haven't done mine yet because when it happens I just turn on the headlights fir a while then turn them off all good 2004 Monaco Dynasty. Link to comment Share on other sites More sharing options...
waterskier_1 Posted December 29, 2021 Share Posted December 29, 2021 19 hours ago, Larry Maida said: The cure you are refereeing to occurs when there are two charging source. On 12/27/2021 at 1:56 PM, Radar22 said: Does anybody know why this light comes on the dash. Just had coached checked for alternator issues and possibly a parasitic draw. All checked out Ok. thanks That light is driven off one AC trail on the generator. If the voltage there subtracted from the chassis battery voltage, is not greater than 6 Volts, the light will come on. If it is intermittent, then it's not likely a fuse. First, check your chassis battery voltage. It should be 14.2 - 14.4 Volts. If not, check right at the alternator. Check for good grounds. Lastly, it could be the 6-volt ALT-FAIL Relay. It's the only 6-volt relay in the coach. 19 hours ago, Larry Maida said: 7 hours ago, Michael Powell said: If you turn tour headlights on and it goes off. There is a kit that uses a relay that fixes that... I haven't done mine yet because when it happens I just turn on the headlights fir a while then turn them off all good 2004 Monaco Dynasty. On 12/27/2021 at 1:56 PM, Radar22 said: Does anybody know why this light comes on the dash. Just had coached checked for alternator issues and possibly a parasitic draw. All checked out Ok. thanks Link to comment Share on other sites More sharing options...
Steven P Posted December 31, 2021 Share Posted December 31, 2021 As others said above, mine will do that if I have the generator running and then crank the engine. If I have the engine running and then crank the genny it doesn't do it so I try to stick to that method. Turning on headlights or parking lights makes it go away. Link to comment Share on other sites More sharing options...
Busnut Posted December 31, 2021 Share Posted December 31, 2021 I had the light come on after an alternator repair. I changed out the relay for the ALT light. I didn't have any luck with that. I changed out the circuit barker in the rear panel. That fixed the problem. Link to comment Share on other sites More sharing options...
Steven P Posted December 31, 2021 Share Posted December 31, 2021 6 hours ago, Busnut said: I had the light come on after an alternator repair. I changed out the relay for the ALT light. I didn't have any luck with that. I changed out the circuit barker in the rear panel. That fixed the problem. Which breaker was it? Link to comment Share on other sites More sharing options...
Michael Powell Posted December 31, 2021 Share Posted December 31, 2021 7 hours ago, Steven P said: As others said above, mine will do that if I have the generator running and then crank the engine. If I have the engine running and then crank the genny it doesn't do it so I try to stick to that method. Turning on headlights or parking lights makes it go away. Turning on the lights is a dead giveaway... I talked to a tech at monaco in 2015 he sent me a fix for that will look for it thus coming week. 1 Link to comment Share on other sites More sharing options...
Busnut Posted January 1, 2022 Share Posted January 1, 2022 15 hours ago, Steven P said: Which breaker was it? It was the driver side rear run panel. Mini breaker labeled VOLT REG 30 AMP Link to comment Share on other sites More sharing options...
Steven P Posted January 1, 2022 Share Posted January 1, 2022 5 hours ago, Busnut said: It was the driver side rear run panel. Mini breaker labeled VOLT REG 30 AMP I'm not familiar w one of those. Any chance you have a pic? Thank you Link to comment Share on other sites More sharing options...
Busnut Posted January 1, 2022 Share Posted January 1, 2022 1 minute ago, Steven P said: I'm not familiar w one of those. Any chance you have a pic? Thank you Just like this one. https://www.digikey.com/en/products/detail/triad-components-group/ACB-12-H-30A/11580705?utm_adgroup=Circuit Breakers&utm_source=google&utm_medium=cpc&utm_campaign=Shopping_Product_Circuit Protection_NEW&utm_term=&utm_content=Circuit Breakers&gclid=Cj0KCQiAlMCOBhCZARIsANLid6YF626UnkaGa7tjrlrl8258X1T3AyTahCBEegCsJvoKcQBK0zUmhOgaAuJ4EALw_wcB Link to comment Share on other sites More sharing options...
Steven P Posted January 1, 2022 Share Posted January 1, 2022 Thank you. I haven't seen one of those on my Diplomat. I'll keep an eye out. Link to comment Share on other sites More sharing options...
Busnut Posted January 1, 2022 Share Posted January 1, 2022 Just now, Steven P said: Thank you. I haven't seen one of those on my Diplomat. I'll keep an eye out. I never would of though it had anything to do with it. I was talking with pwhittle and he suggested changing it out. An wow it was fixed Link to comment Share on other sites More sharing options...
Steven P Posted January 1, 2022 Share Posted January 1, 2022 1 hour ago, Busnut said: I never would of though it had anything to do with it. I was talking with pwhittle and he suggested changing it out. An wow it was fixed Any way I could ask you to post a pic of it on your coach? My drivers rear bay is 110v only. Link to comment Share on other sites More sharing options...
Busnut Posted January 2, 2022 Share Posted January 2, 2022 21 hours ago, Steven P said: Any way I could ask you to post a pic of it on your coach? My drivers rear bay is 110v only. Hope this will help. Link to comment Share on other sites More sharing options...
Steven P Posted January 2, 2022 Share Posted January 2, 2022 Thank you. I have nothing like that I've seen on mine. I'll keep an eye out. Link to comment Share on other sites More sharing options...
