Hancoman Posted December 28, 2021 Share Posted December 28, 2021 Took the motorhome out to fuel up 4.11 a gallon in WA but that’s not the issue. Alternator quit charging when I got back to storage discovered I lost the upper bolt that holds the alternator in place so belt no longer turned. My question is where do I find the proper bolt to replace the lost one. I believe it also attaches to the belt tensioner Link to comment Share on other sites More sharing options...
Tim-AZ Posted December 28, 2021 Share Posted December 28, 2021 I would (guess) it's a 3/8 24 thread bolt. Measure the distance (length) you need and buy at a hardware store. You don't keep a jar of nuts and bolts around? Tim Link to comment Share on other sites More sharing options...
DavidL Posted December 28, 2021 Share Posted December 28, 2021 (edited) All hardware stores sell a plastic partitioned container with various bolts / nuts / washers. Buy an SAE and a Metric set. $40 will save you a lot of trips. Right next to that will be a box of assorted clamps. Get that too. General stuff that every toolbox needs. BTW, look to the left of the alternator...that barrel that is threaded to the long bolt...that is the tensioner. The alternator gets bolted to that. So, bolt those together but leave slightly loose. Tighten the barrel adjustment. When belt is at the proper deflection, then tighten the alternator to barrel bolt (the "missing" one) to tighten the assembly. Edited December 28, 2021 by DavidL 1 Link to comment Share on other sites More sharing options...
Hancoman Posted December 30, 2021 Author Share Posted December 30, 2021 Thanks for your guidance all fixed and ready to roll Tom C Link to comment Share on other sites More sharing options...
