Daniel Posted December 29, 2021 Share Posted December 29, 2021 Can anyone tell me the location of the Window awning control for my 2006 Monaco executive Curbside rear awning will not open I suppose that’s better than will not close lol any help is greatly appreciate it Link to comment Share on other sites More sharing options...
Ivylog Posted December 29, 2021 Share Posted December 29, 2021 (edited) Controlled by the multiplex system and one of the many boards in the BR closet…good luck. I would start by unplugging the cable on the back of the keypad and back in… might fix and easy enough to do. Next step is to turn the 12V power off to the multiplex system which will re-boot the system…same as your computer as this system is computer controlled. Have to disconnect the solar too, not just pushing the salesman switch. Edited December 29, 2021 by Ivylog Link to comment Share on other sites More sharing options...
Daniel Posted January 1, 2022 Author Share Posted January 1, 2022 On 12/29/2021 at 8:08 AM, Ivylog said: Controlled by the multiplex system and one of the many boards in the BR closet…good luck. I would start by unplugging the cable on the back of the keypad and back in… might fix and easy enough to do. Next step is to turn the 12V power off to the multiplex system which will re-boot the system…same as your computer as this system is computer controlled. Have to disconnect the solar too, not just pushing the salesman switch. Thank you we will try The switch angle but I’m not seeing any reference to window awnings nor does any indicator light light up in the rear panel area when I activate other awnings which are working just fine. I read somewhere these awnings might be 120 V and the controls may be in that mess of wiring at the AV area I sure hope not what a puzzle that would be lol Link to comment Share on other sites More sharing options...
Paul A. Posted January 1, 2022 Share Posted January 1, 2022 On 12/28/2021 at 9:16 PM, Daniel said: Can anyone tell me the location of the Window awning control for my 2006 Monaco executive Curbside rear awning will not open I suppose that’s better than will not close lol any help is greatly appreciate it Are they Girard? Link to comment Share on other sites More sharing options...
Ivylog Posted January 1, 2022 Share Posted January 1, 2022 OP, I have multiplex boards behind the front TV, not just in the BR closet. Link to comment Share on other sites More sharing options...
Paul A. Posted January 2, 2022 Share Posted January 2, 2022 23 hours ago, Daniel said: Thank you we will try The switch angle but I’m not seeing any reference to window awnings nor does any indicator light light up in the rear panel area when I activate other awnings which are working just fine. I read somewhere these awnings might be 120 V and the controls may be in that mess of wiring at the AV area I sure hope not what a puzzle that would be lol Are they Girard? Link to comment Share on other sites More sharing options...
