CapnDean Posted January 2, 2022 Share Posted January 2, 2022 2008 Camelot 42P: Ran from Gulfport MS to Charleston SC & Back. When I left Charleston I got an amber warning light flashing for about a dozen flashes, then it quit. Coach ran like a singer sewing machine all the way home. Each time I shut it off and restarted it, I would get the same flashing light for a bit, then it would go out. I did a quick search of the internet and found multiple posts saying that it is the way that the ISL 400 tells you that you have a stored code and you need to read it. My code reader was at home (SIDE NOTE: its always at home when I need it in the coach. If I am on the boat and I need something, its at the house. If I am at the house and I need it...you got it, it's in the RV...and I am not only talking about my code reader) Several of the sites also suggested that their most common code was water in fuel indicator. Well they were spot on. That was the code and that was the problem. I drained the water sep and did not get much water, so I tried to clear the code and my reader would not allow me to clear it. BUT: I changed my fuel filters and you got it..... was able to clear the code. I am glad that I carry spare filters in the coach. This time it didnt even slow the motor down, usually I can feel it when the filter is in need if service. 1 Link to comment Share on other sites More sharing options...
Rick A Posted January 2, 2022 Share Posted January 2, 2022 Always like success stories. Yup code reader like the amp meter is always AWOL. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted January 2, 2022 Share Posted January 2, 2022 Code reader? I thought only Cummins had the code readers. What are the after-market readers? Gary 05 AMB DST Link to comment Share on other sites More sharing options...
RBRODDER Posted April 17, 2022 Share Posted April 17, 2022 (edited) Dean, what code reader do you have? I recently started getting a check engine light on start up for about 5 minutes or so. I would like to know what is triggering the light. 04 Neptune with 5.9 Cummins. Thanks Rich Edited April 18, 2022 by RBRODDER Correction Link to comment Share on other sites More sharing options...
Ivan K Posted April 18, 2022 Share Posted April 18, 2022 In my opinion, the cheapest and easiest is a simple Scangauge D, depending how involved and invested you want to get. It's got both 6 and 9 pin connectors and is a plug and play type thing plus it shows all kinds of readings if you doubt your gauges. Link to comment Share on other sites More sharing options...
RBRODDER Posted April 18, 2022 Share Posted April 18, 2022 (edited) Thanks Ivan. Do you have a Scangauge D? Thanks Rich Edited April 18, 2022 by RBRODDER Correction Link to comment Share on other sites More sharing options...
Ivan K Posted April 18, 2022 Share Posted April 18, 2022 13 hours ago, RBRODDER said: Thanks Ivan. Do you have a Scangauge D? Thanks Rich Yes I do and use it to watch few parameters in normal operation. Link to comment Share on other sites More sharing options...
