piercelarry69 Posted January 6, 2022 Share Posted January 6, 2022 no power to ignition switch. checked for fuses seem fine turn switch nothing. 2001 m Monaco windsor 1 Link to comment Share on other sites More sharing options...
Rikadoo Posted January 6, 2022 Share Posted January 6, 2022 Check power at switch if ok its common for those gm switches to fail Link to comment Share on other sites More sharing options...
myrontruex Posted January 6, 2022 Share Posted January 6, 2022 Are you using a voltmeter or a test light??? How did you check fuses??? A test light is a great way and simple to use. Link to comment Share on other sites More sharing options...
Andrew Sibley Posted January 6, 2022 Share Posted January 6, 2022 Make sure the switch in the rear engine compartment isn’t on. Link to comment Share on other sites More sharing options...
jacwjames Posted January 7, 2022 Share Posted January 7, 2022 Check the battery disconnect. Mine failed and no power on chassis side. I just bolted both wires together until I could get a new disconnect. Link to comment Share on other sites More sharing options...
