Bill C Posted January 7, 2022 Share Posted January 7, 2022 Does anyone know the trick to unplugging this connector on my Triptek. I'm afraid I will really damage it if I pull or pry to hard (looks like one wire has already some off), but that little sucker does not want to come off. What am I missing? Here is a pic Thanks in advance, Bill Link to comment Share on other sites More sharing options...
cbr046 Posted January 7, 2022 Share Posted January 7, 2022 Hard to tell from the one photo. Do those nylon "fingers" lock into anything? Follow the seams and gently pry on them with a jeweler's screwdriver. If anything moves you're on to something. - bob Link to comment Share on other sites More sharing options...
Bill C Posted January 7, 2022 Author Share Posted January 7, 2022 After getting very frustrated I decided to follow the cable and sure enough the other end of the cable came unplugged and I used it to go through the hole and didn’t have to unplug that one that was so hard. I do have to jumper a wire for the one that is broken and that’s gonna be tricky.. Thank you for your assistance Link to comment Share on other sites More sharing options...
cbr046 Posted January 8, 2022 Share Posted January 8, 2022 Instead of fixing the wire consider bypassing and soldering directly to the board. You'll need to connectorize the jumper. And, of course, if you suck at soldering all bets are off. I had to do this with a Mini tail light ground. Finally gave up on the connector and bypassed it. - bob Link to comment Share on other sites More sharing options...
Bill C Posted January 8, 2022 Author Share Posted January 8, 2022 Good suggestion Bob, and I can solder, I'm an ex ET in the Navy 🙂 Link to comment Share on other sites More sharing options...
cbr046 Posted January 8, 2022 Share Posted January 8, 2022 3 hours ago, Corkman said: Good suggestion Bob, and I can solder, I'm an ex ET in the Navy 🙂 So you were a swabbie swapper? (sorry!) My brother served in the same capacity . . . - bob Link to comment Share on other sites More sharing options...
Woody O Posted January 9, 2022 Share Posted January 9, 2022 On 1/7/2022 at 2:24 PM, Corkman said: Does anyone know the trick to unplugging this connector on my Triptek. I'm afraid I will really damage it if I pull or pry to hard (looks like one wire has already some off), but that little sucker does not want to come off. What am I missing? Here is a pic Thanks in advance, Bill Did you unscrew the screw on each end and the pull apart? Link to comment Share on other sites More sharing options...
Bill C Posted January 9, 2022 Author Share Posted January 9, 2022 It looks like the unit is sealed and the screws are only used to secure to the dash. I don’t think and you can unscrew the screws because there’s no head on the other side just the face and keys Link to comment Share on other sites More sharing options...
