Florainer Posted January 9, 2022 Share Posted January 9, 2022 When cleaning the algae (and lichens?) off my roof recently I noticed that there was none on the painted ends, front and rear, or on the narrow painted strip along the sides, It was only on the white area that makes up almost all of the roof. My 2003 HR Imperial has a full-length one-piece fiberglass roof. Why is there no algae/lichens on the painted areas? Also, now that I have it cleaned off (a lot of hard work!), is there anything I can do to discourage its regrowth? The rig is stored here in Florida in the winter, an admittedly ideal condition for algae growth (hot & humid). I've read that copper discourages algae growth, but is that ever used on an RV roof? Thanks for your replies! 1 Link to comment Share on other sites More sharing options...
Paul A. Posted January 9, 2022 Share Posted January 9, 2022 https://dicorproducts.com/ has everything you need to maintain and protect the roof. Link to comment Share on other sites More sharing options...
JohnC3 Posted January 10, 2022 Share Posted January 10, 2022 My suspicion is that the algae is digesting the breaking down gel coat of your white top. You can use the Dicor stuff, but that may not last as long as you like. From anecdotal evidence, I believe that painting the white portion of the roof with Rustolium (sp?) Marine top coat will help for 5-7 years. It will also prevent the streaks down the sides of your rig (what I did it to prevent). It takes 2 coats at about a quart a coat. Look it up over in IRV2 forums. They have looked into a number of products. The paint costs about 18/qt and can be applied with a roller and brush. It takes about 3 days as it needs to dry well between coats. Hope this helps. Link to comment Share on other sites More sharing options...
Florainer Posted January 17, 2022 Author Share Posted January 17, 2022 Considering all the posts on this site, and on IRV2, about dealing with roof chalk, including Mop & Glo-ing, waxing, painting, etc., why did Monaco/HR not paint the fiberglass roofs of their motorhomes? One reason I can think of is slipperiness, which could add to the danger of going on the roof, but are there other reasons? 🤔 And if the treatments talked about on these sites do increase the slip danger of the roof is that something to consider before going ahead? 🤔 Link to comment Share on other sites More sharing options...
