Rick A Posted January 16, 2022 Share Posted January 16, 2022 If you look at a new slide gate valve its lubricated with Petroleum Jelly (Vaseline). As they get older they tend to get stiff and difficult to close. This is when the trouble starts. I've have had my present values for about 7 years and they are still happy. I managed to keep them lubed by drilling a 1/8" hole at the top of the housing cap and squirting Vaseline into the slide valve with a small syringe. I used a Stainless steel screw to seal it off. You can then lube it regularly. 1 Link to comment Share on other sites More sharing options...
Corkman Posted January 16, 2022 Share Posted January 16, 2022 How do you get the Vaseline into a syringe? 1 Link to comment Share on other sites More sharing options...
Hancoman Posted January 17, 2022 Share Posted January 17, 2022 Very carefully Somebody had to say it 1 Link to comment Share on other sites More sharing options...
Rick A Posted January 17, 2022 Author Share Posted January 17, 2022 21 minutes ago, Corkman said: How do you get the Vaseline into a syringe? I heated in the microwave until it was hot. Link to comment Share on other sites More sharing options...
redstickbill Posted January 17, 2022 Share Posted January 17, 2022 Good thinking outside the box about heating the petroleum jelly. If I remember correctly, a number of years ago there was a note on the old Bill D's site about drilling a hole in the valve cover and tapping for a small zerk fitting to periodically lubing the valve. Bill B 07 Dynasty ( an old guy) 1 Link to comment Share on other sites More sharing options...
1nolaguy Posted January 17, 2022 Share Posted January 17, 2022 Hi Rick A. I have a 2005 Safari Cheetah, which in many ways is similar to the 2005 Dynasty. I am not familiar with a slide gate valve. Can you post a photo and approximate location of it? also, how may of them are there per slide? Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted January 17, 2022 Share Posted January 17, 2022 Hi Rick A, could you send me a photo too? Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Chargerman Posted January 17, 2022 Share Posted January 17, 2022 It’s not a valve for your slide. Its the dump valves for your grey and black tank. 1 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted January 17, 2022 Share Posted January 17, 2022 DUH! I knew that. LOL! Gary05 AMB DST Link to comment Share on other sites More sharing options...
Rick A Posted January 17, 2022 Author Share Posted January 17, 2022 Just now, Rick A said: Hope this helps folks. 1 hour ago, 1nolaguy said: Hi Rick A. I have a 2005 Safari Cheetah, which in many ways is similar to the 2005 Dynasty. I am not familiar with a slide gate valve. Can you post a photo and approximate location of it? also, how may of them are there per slide? Loel, we meet again. Hi. This is the sewer dump valve. I put up a photo. 47 minutes ago, Gary 05 AMB DST said: Hi Rick A, could you send me a photo too? Gary 05 AMB DST I posted the photo (courtesy Amazon). Link to comment Share on other sites More sharing options...
John Rowin Posted January 17, 2022 Share Posted January 17, 2022 I put a few drops of virgin coconut oil in my toilet bowl. This lines the ball valve all the way through the system. Link to comment Share on other sites More sharing options...
1nolaguy Posted January 17, 2022 Share Posted January 17, 2022 Rick A, thank you for posting the photos. I suspected that is what you were referring to but wanted to be sure. John Rowin, your approach is interesting however have you noticed any issues of grease build up in your black and grey water systems? Coconut oil is generally solid at room temperature. At winter temp it is almost hard. Do you periodically pass hot water through the system to flush out buildup? Link to comment Share on other sites More sharing options...
Dr4Film Posted January 17, 2022 Share Posted January 17, 2022 I use the soapy grey water to lubricate the dump valve blades as the grey tank is always the last one emptied. Empty the black first, leave valve open. Empty grey tank, when the last of the grey is rolling out which is always the soapy water, close the black valve followed with the grey valve. Never have had any sticking valves using this method for the past 14 years that these valves have been installed. 1 Link to comment Share on other sites More sharing options...
tomevansfl Posted January 20, 2022 Share Posted January 20, 2022 I discovered I have a drip from my black tank. I replaced the valve and it was hard to close so I replaced it with a different brand but still getting a drip. I feel like the first time I replaced it the O-ring on one side bunched up and was causing the leak. I made sure it didn't happen the second time. Has anyone else had a leak that wasn't because of the slide valve? What did you do? Link to comment Share on other sites More sharing options...
Rick A Posted January 20, 2022 Author Share Posted January 20, 2022 Curious, is the leak inside the valve or on the outside? Link to comment Share on other sites More sharing options...
tomevansfl Posted January 20, 2022 Share Posted January 20, 2022 9 hours ago, Rick A said: Curious, is the leak inside the valve or on the outside? I'm not really sure where the drip is coming from. It is dripping from the valve area so it could be the O-ring or one of the joints nearby. I drips down into the wet bay and then onto the ground. I haven't been able to stop it. I really don't like the idea of it dripping on the ground. I was at a electric/water only site so the hose opening had the "lid" screwed in, but some was still dripping out. When I dumped, there was a good half inch of black water in the bottom of the wet bay. Link to comment Share on other sites More sharing options...
Dr4Film Posted January 20, 2022 Share Posted January 20, 2022 My guess is that you have crunched one of the O-rings that seals the valve to each side of the 3-inch pipe fixtures. Disassemble to look at the O-rings and replace with new O-rings. 1 Link to comment Share on other sites More sharing options...
Ray Davis Posted January 20, 2022 Share Posted January 20, 2022 Van Williams discussed the oring issue a while back and he made a simple device to gently spread the pipes for easier install. Here is a picture he posted. 1 Link to comment Share on other sites More sharing options...
Rick A Posted January 20, 2022 Author Share Posted January 20, 2022 3 hours ago, tomevansfl said: I'm not really sure where the drip is coming from. It is dripping from the valve area so it could be the O-ring or one of the joints nearby. I drips down into the wet bay and then onto the ground. I haven't been able to stop it. I really don't like the idea of it dripping on the ground. I was at a electric/water only site so the hose opening had the "lid" screwed in, but some was still dripping out. When I dumped, there was a good half inch of black water in the bottom of the wet bay. Sounds like one of the O ring has AWOLed. They can be difficult to position. Van Williams gadget might have help but it had been invented yet when I needed it. Hahaha. Patience and leverage. Link to comment Share on other sites More sharing options...
StephenW Posted January 20, 2022 Share Posted January 20, 2022 I recently had a drip around my waste gate valve and found the ABS plastic glue fitting on the slide gate had cracked. For a temporary fix I put ABS glue around the crack and put a hose clamp around the outside of the fitting. I eventually replaced the whole setup with a Valterra Double Ell waste gate valve assembly. It would have been a lot easier with the Van Williams tool. Also, when putting in o-rings I like to use a silicone O-ring lube. This helps the O-ring stay in place and not snag or bunch up. 1 Link to comment Share on other sites More sharing options...
tomevansfl Posted January 22, 2022 Share Posted January 22, 2022 RV is currently at storage facility but I will go over and try these suggestions before my next trip President's weekend. Thanks everybody! Link to comment Share on other sites More sharing options...
Corkman Posted January 27, 2022 Share Posted January 27, 2022 On 1/16/2022 at 5:51 PM, Rick A said: If you look at a new slide gate valve its lubricated with Petroleum Jelly (Vaseline). As they get older they tend to get stiff and difficult to close. This is when the trouble starts. I've have had my present values for about 7 years and they are still happy. I managed to keep them lubed by drilling a 1/8" hole at the top of the housing cap and squirting Vaseline into the slide valve with a small syringe. I used a Stainless steel screw to seal it off. You can then lube it regularly. Rick, is the slide gate valve open or closed when you squirt the Vaseline in the 1/8" hole? My slide valve is set up with the hole and screw already. I read another post from someone a while ago suggesting this type of lubricating method, but he suggested using white lithium grease. I tried this grease and was not happy with the results. I will try Vaseline next time 🙂 Link to comment Share on other sites More sharing options...
Dr4Film Posted January 27, 2022 Share Posted January 27, 2022 Be careful with the type of "lubricant" you decide to use as some may cause the O-rings to swell and that would not be good either. Link to comment Share on other sites More sharing options...
Rick A Posted January 27, 2022 Author Share Posted January 27, 2022 37 minutes ago, Corkman said: Rick, is the slide gate valve open or closed when you squirt the Vaseline in the 1/8" hole? My slide valve is set up with the hole and screw already. I read another post from someone a while ago suggesting this type of lubricating method, but he suggested using white lithium grease. I tried this grease and was not happy with the results. I will try Vaseline next time 🙂 I tried grease on and old one and it went hard and make the valve stiff. I Stick with Vaseline and I spray in hot with the valve open work it back a forth 3 or 3 times. Link to comment Share on other sites More sharing options...
