bradc344 Posted January 18, 2022 Share Posted January 18, 2022 Hello I posted earlier about my problem with my ac/heater fan not working at all I put in a new resistor and it will work on high only not sur what to replace now the switch is all so new do you think replacing the fan motor would help? I had it out and it turned freely any ideas thanks Brad Link to comment Share on other sites More sharing options...
Cubflyer Posted January 18, 2022 Share Posted January 18, 2022 My experience with those fan motors is that the speed that they run at (low, Med, Hi) is controlled with the resistor by changing the voltage supplied to the motor. So, my guess here is that the problem is in the circuit, not the fan motor. Link to comment Share on other sites More sharing options...
klcdenver Posted January 19, 2022 Share Posted January 19, 2022 Did you match the number of terminals and orientation to the old resistor. Some times they are not the same but the plug will still fit the resistor. But usually when you have only high it is the resistor. Pull it out and see if one of the coils have burnt into. 1 Link to comment Share on other sites More sharing options...
Keamyinc Posted February 20, 2022 Share Posted February 20, 2022 Hi Brad, I’m wondering if you ever got your fan working on all settings? I have the same problem and need to attack it. I’m wondering what you found out that you can share.Thanks Don Link to comment Share on other sites More sharing options...
bradc344 Posted February 20, 2022 Author Share Posted February 20, 2022 yes I did but had to jump relay ignition one to get it to work for some reason I dont have any power to that relay work fine just have to turn the system off withe dash switch. still working on a solution but for now it works fine did you check your resistor if it work on high speed only then it might be the resistoryou can get them on amazon for $18.00 Napa want $50.00 go figure good luck Link to comment Share on other sites More sharing options...
