flyindale Posted January 21, 2022 Share Posted January 21, 2022 Hi everyone ! I have a 2011 Knight with a 10kw Onan QD. with a Magnum AGS controller. When I use the test function on the AGS it functions normally. When I use either of the 2 manual start switches in the coach the gen starts fine once, then will not start a second time from either one. After that the switch on the gen unit will start it every time, but will give me a config. error code 37. If I unplug the aux. harness from gen. and reconnect it all switches work once, but 2nd attempt creates same problem again. I unplugged the AGS and there was no change in the issue. Any thoughts or insight would be greatly appreciated. Thanks Dale G. Link to comment Share on other sites More sharing options...
