Oregon04Windsor Posted January 24 Share Posted January 24 I've noticed a loud clunk that is heard and felt from the rear of the coach. It's intermittent and rare but when it does happen it seems to be when climbing a hill and you let off then go back on the throttle. I don't think it's a hard shift...I'm well versed in the Allison hard shifts! Maybe more like a driveline issue or something in the suspension loading up then slamming? Has anyone experienced anything like this with the Roadmaster Chassis? 2004 Windsor 40PKD with 16,000 miles. Link to comment Share on other sites More sharing options...
Idoc57 Posted January 24 Share Posted January 24 Have you checked the u-joints on both ends of the driveshaft? They sometimes get overlooked when greasing the chassis. Some of them have 2 zerks, so be sure to grease both if your u-joints have 2. If they haven't been maintained regularly, the grease might have gotten hard and you might only be getting fresh grease into one or two of the 4 cups. In that case, I would recommend removing the, driveshaft and u-joints. Take them apart and thoroughly clean them before filling them with fresh grease. Be careful not to lose any of the needle bearings. Of course you could just buy two new ones and install them. Carey 1 Link to comment Share on other sites More sharing options...
Jdw12345 Posted January 24 Share Posted January 24 I would drain the rear differential and see if you find anything…… 1 Link to comment Share on other sites More sharing options...
Ray Davis Posted January 24 Share Posted January 24 I don't want to scare you, but you might want to look at all of the welds in the rear. Broken welds are not common but have happened. Here is a thread shoeing what can happen. https://www.monacoers.org/topic/2338-broken-welds-and-broken-rollers/#comments 1 Link to comment Share on other sites More sharing options...
Jdw12345 Posted January 24 Share Posted January 24 Mr Davis has an excellent point! Link to comment Share on other sites More sharing options...
jacwjames Posted January 24 Share Posted January 24 I agree with Ray, broken welds can be a potential source for the sound. You might also check bushings. If you are not capable of crawling under the rig with a good light I'd take it somewhere and have them inspect. I've been seeing more and more of these posts then show cracks in welds on the main axle supports or trailing arms. I do my own maintenance and every time I'm under my coach I drag a shop light underneath and closely inspect the main supports and anything else I can see. If a problem is caught soon enough it is much easier to repair then if there is a complete failure. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted January 24 Share Posted January 24 Sounds like you have bad universal joints. You need to change them out ASAP because if they fail, you can drop your drive shaft causing a lot of damage to the transmission, engine, and drive shaft. Monaco recommends greasing the universal joints every 5,000 miles. 1 Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted January 24 Author Share Posted January 24 Thanks for the input, I'll take a closer look this week. I have lubed the shaft and joints. It's so intermittent and that's what makes it annoying. I've tried to replicate but can't do it at will. Link to comment Share on other sites More sharing options...
CTerry Posted January 24 Share Posted January 24 Could be the U joints. Only 16,000 miles. Have they been ever greased. When I bought my motorhome in Indiana we drove straight home to CA. When I went to grease it the u joints would not take grease at all. When I pulled them out they had something other than grease in them. Hard and stiff. Surprised we got home, Just replaced them. Although u joints make a pretty constant vibration if going bad. Would really check mountings on rear axle. Link to comment Share on other sites More sharing options...
Paul A. Posted January 24 Share Posted January 24 27 minutes ago, Oregon04Windsor said: Thanks for the input, I'll take a closer look this week. I have lubed the shaft and joints. It's so intermittent and that's what makes it annoying. I've tried to replicate but can't do it at will. Busted shock mount?? I think it's a structural issue. U joint would be constant and the vibration would be horrendous. 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted January 24 Share Posted January 24 Depends on how worn and dry they are. Link to comment Share on other sites More sharing options...
Ron L. Posted January 24 Share Posted January 24 I was getting a hard shift in my 2000 Dynasty, cruise control and jake brake do not work well with each other in up and down rolling hills. When approaching up and downgrades try turning either the cruise off OR the Jake brake. Link to comment Share on other sites More sharing options...
vanwill52 Posted January 25 Share Posted January 25 As several other highly regarded posters mentioned, check your rear support uprights. They are generally 3" square tubing. Initially, cracks may be hard to see, but if you don't have "buttress" plates welded onto your main frame rails, you will want to add them, EVEN IF THAT IS NOT THE REASON for your noise. They are a well-known failure item. Although no facility in the country probably has more experience dealing with correcting this problem than Josam's in Orlando, FL, there are no doubt countless heavy-duty truck shops (and even more talented "amateurs") who can deal with this problem. Dave Pratt, our founder, has had intimate knowledge of repairing this failure. Hopefully, he will chime in...even though he is a traitor and is one of the SOB group. 😄 1 1 Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted January 25 Author Share Posted January 25 Crawled under tonight for a cursory look and didn't see anything obvious. Naturally I'll do a full inspection when it's not 30 degrees out. I did have a thought: I was towing our Chevy Tracker and I wonder if what I heard and felt was the tow car taking up slack then pulling back hard when I got on the throttle? Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted January 25 Share Posted January 25 8 hours ago, Oregon04Windsor said: Thanks for the input, I'll take a closer look this week. I have lubed the shaft and joints. It's so intermittent and that's what makes it annoying. I've tried to replicate but can't do it at will. When you say shaft, do you mean the slip joint on the drive shaft? Is the Windsor the Monaco version of the Holiday Rambler Endeavor? Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted January 25 Share Posted January 25 No, the Diplomat is the Endeavor version. The Imperial is the HR version of the Windsor. Link to comment Share on other sites More sharing options...
Jerry G Posted January 25 Share Posted January 25 Since it only happens going up hill and "putting it to it" could it be time for a fuel filter? Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted January 25 Author Share Posted January 25 Just now, Jerry G said: Since it only happens going up hill and "putting it to it" could it be time for a fuel filter? Filters are new and there's no loss of power; also, it's really intermittant. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted January 25 Share Posted January 25 46 minutes ago, Jerry G said: Since it only happens going up hill and "putting it to it" could it be time for a fuel filter? That tells me it's the universal joints. Been there and experienced that. Link to comment Share on other sites More sharing options...
Rob M cKeown Posted January 25 Share Posted January 25 I had a similar issue on my 03 Signature, it was broken welds on the vertical members on the chassis that secure the suspension trailing arms I also noticed it when braking Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted January 27 Author Share Posted January 27 I gave the rear chassis a thorough going over today and I'm happy to report there's no cracked welds, broken mounts or broken shocks. The trailing arms are in excelletn condition too. I gave the driveline a thorough lubing and we will keep an eye on it. I'm really hoping it was just the tow car slamming around back there. Link to comment Share on other sites More sharing options...
Chargerman Posted January 27 Share Posted January 27 In order to properly inspect the universal joints you Remove the driveshaft as driveline pressure will not allow you To feel any free play. Link to comment Share on other sites More sharing options...
Ray Davis Posted January 27 Share Posted January 27 10 hours ago, Oregon04Windsor said: I'm really hoping it was just the tow car slamming around back there That's a reasonable next area to suspect, but you may want to look further into the towbar & base plate especially where it bolts to the car. There have been cases where the base plate becomes loose, some even becoming completely detached. Better hope those safety cables hold if that happens, but the cables are attached to the base plate, that's what just came detached from the car, Hum. You would think if the drive line ( u joints etc ) were worn / loose enough to make a clunk that you would be able to feel the looseness when under the coach, but I certainly can't say that's the case. As Chuck stated a dropped drive shaft can dig into the road causing extensive damage. That actually happened to a past memebr. Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted January 27 Author Share Posted January 27 Good points Ray and Chuck. I did give the tow bar a cursory check but I'll go through and tighten everything up there as needed. I did order new u-joints for the drivelines as a precautionary measure and will install before our next voyage. 2 Link to comment Share on other sites More sharing options...
Chargerman Posted January 27 Share Posted January 27 Good plan! Link to comment Share on other sites More sharing options...
