Connie B Posted January 24, 2022 Share Posted January 24, 2022 (edited) Does anyone have any suggestions how to access the connection for these rope lights? I have like behind the trim, under the drawer, and in the cabinet under the sink. I have not removed the long piece of trim that runs from the sink to under the stove top. If anyone has had success or suggestions I would appreciate it. Edited January 24, 2022 by Connie B Link to comment Share on other sites More sharing options...
jacwjames Posted January 24, 2022 Share Posted January 24, 2022 58 minutes ago, Connie B said: Does anyone have any suggestions how to access the connection for these rope lights? I have like behind the trim, under the drawer, and in the cabinet under the sink. I have not removed the long piece of trim that runs from the sink to under the stove top. If anyone has had success or suggestions I would appreciate it. Have you tried to lift up the bottom of the cabinet. All my floor cabinets have false bottoms that I can lift up. Link to comment Share on other sites More sharing options...
BillDeb45 Posted January 24, 2022 Share Posted January 24, 2022 Ours is located in the slated access panel beside doors under sink Link to comment Share on other sites More sharing options...
vito.a Posted January 24, 2022 Share Posted January 24, 2022 Connie, what model coach do you have? On our 2004 Signature I found the connection for the kitchen cabinet rope light under the false floor that is for pots and pans under the cooktop. It is 12v. I found the connection for the bathroom rope light under the bathroom cabinet. I removed the bottom bathroom drawer and was able to reach in under the cabinet and access that connection. I purchased 12v LED rope light rolls on Amazon fairly inexpensively. I was able to use them for replacing both the small fluorescent lights and the under cabinet rope lights. The only caution is to avoid the very bright LEDs light rolls as the originals are only a warm white. Link to comment Share on other sites More sharing options...
Connie B Posted January 26, 2022 Author Share Posted January 26, 2022 (edited) On 1/24/2022 at 11:21 AM, jacwjames said: Have you tried to lift up the bottom of the cabinet. All my floor cabinets have false bottoms that I can lift up. I’ll check that out. I had no idea on that. Thanks On 1/24/2022 at 2:03 PM, vito.a said: Connie, what model coach do you have? On our 2004 Signature I found the connection for the kitchen cabinet rope light under the false floor that is for pots and pans under the cooktop. It is 12v. I found the connection for the bathroom rope light under the bathroom cabinet. I removed the bottom bathroom drawer and was able to reach in under the cabinet and access that connection. I purchased 12v LED rope light rolls on Amazon fairly inexpensively. I was able to use them for replacing both the small fluorescent lights and the under cabinet rope lights. The only caution is to avoid the very bright LEDs light rolls as the originals are only a warm white. Vito We have a 2006 Executive. That’s probably where it is. I will check and let everyone know. Thanks so much. On 1/24/2022 at 11:33 AM, BillDeb45 said: Ours is located in the slated access panel beside doors under sink If I don’t find in one of the other locations I’ll check this one also. Thanks for the response. Edited January 29, 2022 by Connie B Link to comment Share on other sites More sharing options...
Bill R Posted January 27, 2022 Share Posted January 27, 2022 On 1/24/2022 at 1:03 PM, vito.a said: Connie, what model coach do you have? On our 2004 Signature I found the connection for the kitchen cabinet rope light under the false floor that is for pots and pans under the cooktop. It is 12v. I found the connection for the bathroom rope light under the bathroom cabinet. I removed the bottom bathroom drawer and was able to reach in under the cabinet and access that connection. I purchased 12v LED rope light rolls on Amazon fairly inexpensively. I was able to use them for replacing both the small fluorescent lights and the under cabinet rope lights. The only caution is to avoid the very bright LEDs light rolls as the originals are only a warm white. Vito - can you share the link of the one's your purchased? Mine are out too. There are so many options I want to make sure I purchase what worked for you. Link to comment Share on other sites More sharing options...
vito.a Posted January 27, 2022 Share Posted January 27, 2022 Browse Amazon for LED strip lights. You need 12v warm white. I used these and cut them to length. I also used similar light strips to replace our fluorescent tubes and removed the ballast. https://www.amazon.com/Flexible-Dimmable-Kitchen-Cabinet-Bedroom/dp/B07TJQX1XT/?_encoding=UTF8&pd_rd_w=2pM04&pf_rd_p=29505bbf-38bd-47ef-8224-a5dd0cda2bae&pf_rd_r=1TERXGZX0C99C2X2B5D5&pd_rd_r=f37e10fd-f468-4911-b4f6-736d736190e0&pd_rd_wg=j7k82&ref_=pd_gw_ci_mcx_mr_hp_atf_m I used these connectors. https://www.amazon.com/LightingWill-Solderless-Conductor-Connector-Single/dp/B01DM7EXX2/ref=pd_bxgy_img_2/138-7088111-0188033?pd_rd_w=Sr90E&pf_rd_p=c64372fa-c41c-422e-990d-9e034f73989b&pf_rd_r=YQD01GB2FQWEZR7SZWC6&pd_rd_r=fbe1d072-1332-41f8-a676-fb5506df993a&pd_rd_wg=7JdIj&pd_rd_i=B01DM7EXX2&psc=1 Link to comment Share on other sites More sharing options...
Ivylog Posted January 28, 2022 Share Posted January 28, 2022 (edited) The LED strips are the only LEDs I’ve had trouble with…don’t last very long. It would have been easier and looked better to run a strip along the bottom of the upper kitchen cabinets BUT not going to make that mistake a 4th time like I did in the bathroom’s bottom cabinet. Used six 48 led panels instead of a strip and 3 years later every chip is still working. As much as they get used, I’ll guarantee you I couldn’t say the same if I’d used a strip. If you use a strip, don’t hard wire it in…use the small 2 pin connector so you can replace easier. Edited January 28, 2022 by Ivylog Link to comment Share on other sites More sharing options...
Ivylog Posted January 28, 2022 Share Posted January 28, 2022 (edited) Had a question about the panels I used as nightlights in the kick area on the bottom of the bathroom cabinets… used two 12 LED 5050 panels under a full-size cabinet, so 3 total. The 48 led panels were used under the upper kitchen cabinets. I also use them instead of strips in my fluorescent fixtures…4 in each 18”. I still buy on EBay as they were sold there long before Amazon. I’ve had good luck with the G4 (2 pin) 12 SMD 5050 led bulbs which 12+ years ago, bulbs were $2, but only $1 today. Edited January 28, 2022 by Ivylog Link to comment Share on other sites More sharing options...
