Robert92867 Posted January 26, 2022 Posted January 26, 2022 I am trying to source a replacement switch. Apparently, it "makes" to ground when wet bay door opens, enabling light if system switch is turned on.
OhReally Posted January 26, 2022 Posted January 26, 2022 Here you go. -Jamie Universal Auto Car Trunk Door Alarm Light Hood Jamb Pin Switch Bonnet Pack of 4
Dwight Lindsey Posted January 26, 2022 Posted January 26, 2022 This one may work: Pin Switch Adjustable Momentary ON Off 12VDC 20A There's one review that says it was used in exactly the wet bay switch application. I was looking at mine the other day and it's seriously corroded. Your request for a replacement triggered me to search on Amazon. I've ordered one of these, they're cheap enough, and I'll see if they work. One of the reviewers complained that the picture is a package of 3 switches and there were only two in the package he received. I only need one . . . Dwight
Bjohnsonmn Posted January 26, 2022 Posted January 26, 2022 I just ordered and installed these on my 2000 Windsor. Worked great! 4Pcs Door Pin Switch Momentary Light Switch K-025-I
Robert92867 Posted January 26, 2022 Author Posted January 26, 2022 Nice! Price is right, and tomorrow delivery.
cbr046 Posted January 27, 2022 Posted January 27, 2022 Hmmm . . . my wet bay has a loose wire sticking out at the top. If I ground the wire the light comes on. 💡 I guess my "switch" died a long time ago and got trashed. - bob
Bjohnsonmn Posted January 27, 2022 Posted January 27, 2022 23 minutes ago, cbr046 said: Hmmm . . . my wet bay has a loose wire sticking out at the top. If I ground the wire the light comes on. 💡 I guess my "switch" died a long time ago and got trashed. - bob I have the same thing! I can't find where it was mounted, but the light and wiring is all there and ready to go when I figure out how I want to mount it.
OhReally Posted January 27, 2022 Posted January 27, 2022 You'll notice a tab on the end of any of the Amazon switches. The wire you refer to should simply connect to that tab. Since the complete switch mounts to the door frame through a grounded surface, the wire will ground when the door opens and let's the switch close.
cbr046 Posted January 27, 2022 Posted January 27, 2022 16 minutes ago, Bjohnsonmn said: I have the same thing! I can't find where it was mounted, but the light and wiring is all there and ready to go when I figure out how I want to mount it. I was thinking a simple 'L' bracket on the lift support. Mounting bolt is already there . . . or maybe a new bracket up high out of the way. Or maybe when the weather warms up I'll actually buy the switch! - bob
