hbr509 Posted January 29 Share Posted January 29 I spent the morning trying to find fuse for the fan switch ,any ideas ?? I ck the fuse at the fan itself and its good but the display under the counter does not light up or work, And yes I checked the owners book and looked in fuse bay and nothing , Any help would be great . Thanks Link to comment Share on other sites More sharing options...
ncsteve Posted January 29 Share Posted January 29 I would check the spring loaded switch that activates the fan when the lid opens. Mine was not making contact and caused it to no work. Providing the lid is opening. Link to comment Share on other sites More sharing options...
hbr509 Posted January 30 Author Share Posted January 30 Thanks I pushed the button to manual and it started to raise a couple of inches then nothing , no lights on panel Link to comment Share on other sites More sharing options...
hbr509 Posted January 30 Author Share Posted January 30 I down loaded the schematics from the site and found the fuse page but doesn't tell me location of fuse panel anyone know if there is a second location inside the coach? Link to comment Share on other sites More sharing options...
Ivylog Posted January 30 Share Posted January 30 I would find the 12v fuse block, often in the bathroom or next to the 120V breaker panel. Pretty sure the fuse is there. Link to comment Share on other sites More sharing options...
hbr509 Posted January 30 Author Share Posted January 30 Found it in the bedroom closet 15 amp fuse blown Link to comment Share on other sites More sharing options...
brokenarrow1244 Posted January 30 Share Posted January 30 Mine tends to get stuck against the seal on top, I just push on it a little and it pops loose and continues to raise. I also have a fuse built in that has a small fuse sized knob access from inside the coach Link to comment Share on other sites More sharing options...
