gdroberson Posted January 30, 2022 Share Posted January 30, 2022 I know this has probably been ask before but does anyone know what code reader will work on this 5.9 cummins engine the only place I can find to plug is back at the rear right side of the radiator is a 7 pen connector for the engine cant find nothing under the dash to hook up a scanner nay help would be appreciated thanks Link to comment Share on other sites More sharing options...
Marine Boy Posted January 30, 2022 Share Posted January 30, 2022 I previously owned an HR Ambassador. Every place I had it serviced couldn't find a dash connector. I knew there had to be one, so I went digging. Searching through the access on the top of the dash tied up in the harness I found a 6 pin 1708 socket. It is there, just keep looking. Link to comment Share on other sites More sharing options...
1nolaguy Posted January 30, 2022 Share Posted January 30, 2022 Try Scan Guage / Scan Guage D for Diesel. They can possibly tell you if there gauge will work and possibly where the connection is. Link to comment Share on other sites More sharing options...
gdroberson Posted January 31, 2022 Author Share Posted January 31, 2022 thanks and I will keep looking Link to comment Share on other sites More sharing options...
Mike in Va Posted January 31, 2022 Share Posted January 31, 2022 I have a 2001 HR with the cummins 5.9 and there should be a 6 pin connection under the front dash board. There is also a connection strapped on the passenger side between the passenger side of the motor and frame in the rear of the mh. Hope this helps. Link to comment Share on other sites More sharing options...
gdroberson Posted January 31, 2022 Author Share Posted January 31, 2022 Found it took the steering cover off and was tie wrap to the top of steering wheel bracket thanks again for your help Link to comment Share on other sites More sharing options...
