MrAmbassador Posted February 3, 2022 Share Posted February 3, 2022 We just went through some heavy rain and two of windows leaked. Does anyone know of seal replacement for them or do I need purchase new windows. Where can I buy seals and windows? 2007 Holiday Rambler Ambassador. Thank you for your help! Link to comment Share on other sites More sharing options...
Mark Holt Posted February 3, 2022 Share Posted February 3, 2022 I had a similar issue on the driver seat side window. Water leaked into the trough in the frame. It appeared to be sealed all around but leaked in heavy rain or during wash. the window had some fogging around the edges so i had company come out to correct the fogging and at the same time when the window frame went back in they ran a good bead of the black butyl rubber sealant around the frame. Then butyl rubber rather than silicone around the perimeter as is done on windshield. No leaks even under high pressure water. 1 Link to comment Share on other sites More sharing options...
Seward G Posted February 3, 2022 Share Posted February 3, 2022 I have had leaks around windows and was sure it was something about their frames. Turns out there were leaks in the roof seams above the windows. 1 Link to comment Share on other sites More sharing options...
Martinvz Posted February 4, 2022 Share Posted February 4, 2022 The leaks can be anywhere. The windows are often the culprits. Until you can have the windows removed and reinstalled using calking is a good option. Use some painters tape to limit the calking spread. Replacing the complete window may be difficult and expensive. 1 Link to comment Share on other sites More sharing options...
MrAmbassador Posted February 4, 2022 Author Share Posted February 4, 2022 Thank you everyone for your expert input. Thankfully there are no roof leaks. It was very obvious it was coming from the window. I will remove them and reinstall with the proper caulking. Yes, I will use the painters tape 👍🏼. Again thank you to all! Link to comment Share on other sites More sharing options...
woodylmiller Posted February 6, 2022 Share Posted February 6, 2022 We had the drivers side fixed window fog after going through a truck wash. Took a long time to find a replacement, months. Finally a new window was found. Cost installed: $4,000.00. Insurance covered all except for the $250.00 deductible. Lesson here is most likely you will need to have windows made for the older Monaco's. Woody Miller 09 Dynasty 1 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted February 6, 2022 Share Posted February 6, 2022 Suncoast Designers in Hudson Fl. They replaced two of my windows because of fogging. They have overnight parking and power. Gary 05 AMB DST 1 Link to comment Share on other sites More sharing options...
96 EVO Posted February 6, 2022 Share Posted February 6, 2022 On 2/4/2022 at 10:57 AM, MrAmbassador said: Thank you everyone for your expert input. Thankfully there are no roof leaks. It was very obvious it was coming from the window. I will remove them and reinstall with the proper caulking. Yes, I will use the painters tape 👍🏼. Again thank you to all! The two windows I've had out (so far), I've tossed the factory rubber gasket, and replaced with butyl tape. 1 Link to comment Share on other sites More sharing options...
