oregondarrell Posted February 10, 2022 Posted February 10, 2022 The passenger rear slide on 2004 Monterey wont come in. Check and cleaned contacts on switch, checked 12 volt fuse. Where do I look next, never had a problem with slide before. Darrell Terry 503-547-7819 http://beaveramb.org/forum/Themes/default/images/icons/modify_inline.gif
Rick A Posted February 10, 2022 Posted February 10, 2022 Had a similar issue when I first got my 2005 Diplomat. Found a black covered box in the battery bay with a lot of electrical plugs. I can’t remember all the details but I unplugged each one and sprayed them with contact cleaner. Seamed to fix it? Good luck. 2
Bob Schmeckpeper Posted February 10, 2022 Posted February 10, 2022 Check your manual, should be manual over ride somewhere. Is it Hydraulic or gear drive?
Ivan K Posted February 10, 2022 Posted February 10, 2022 Do you have any baggage doors under that slide that might have a failed safety switch to confirm that they are closed?
BradHend Posted February 10, 2022 Posted February 10, 2022 (edited) Might as well cross off some basics…there’s an ignition interlock. Is your key off? Is it just that slide that won’t come in? Do you notice lights dimming when you attempt to bring it in? Do you have a meter to check fuses/power/switches? Edited February 10, 2022 by BradHend
jacwjames Posted February 10, 2022 Posted February 10, 2022 I have a slide controller in my rear passenger side electrical bay, it has some relays on it, a 5 amp fuse and a ~25 amp circuit breaker. Every once in a while the 5 amp fuse will blow for some reason, replace the fuse and it fixes it for another 3/4 years. It looks like this http://www.nwrvsupply.com/product/KIBSOC1020AWD.html 1
1nolaguy Posted February 10, 2022 Posted February 10, 2022 1 hour ago, oregondarrell said: The passenger rear slide on 2004 Monterey wont come in. Check and cleaned contacts on switch, checked 12 volt fuse. Where do I look next, never had a problem with slide before. Darrell Terry 503-547-7819 http://beaveramb.org/forum/Themes/default/images/icons/modify_inline.gif If there is no power at all going to slide motor. Check ceiling of cargo bays below slide. I had a similar issue last year. Turned out I had a broken connection near one of the basement light fixtures. Did a temp splice until I could do a permeate repair, but the slide worked fine as soon as I made a proper connection. 1
Gary Cole Posted February 10, 2022 Posted February 10, 2022 (edited) If all else fails jump directly to the slide motor from the batteries. You can touch the conductors to the battery posts. Not enough amperage to be a hazard. If you don't have wire you could use extension cords or whatever you could scavenge. Swap polarity if the motor runs in the wrong direction. Edited February 10, 2022 by Gary Cole 1
Deepseated Posted February 10, 2022 Posted February 10, 2022 Dewalt battery to the slide motor with two short alligator clipped jumpers.
oregondarrell Posted February 10, 2022 Author Posted February 10, 2022 I have power to the switch. It's something between switch and pump, possibly a dead solenoid or accuator. Thanks for ideas. I found a mobile repairman that has worked on that X frame type of hydraulic slide before and is coming out tomorrow. Thanks again
Dave Pumphrey Posted February 11, 2022 Posted February 11, 2022 18 hours ago, oregondarrell said: I have power to the switch. It's something between switch and pump, possibly a dead solenoid or accuator. Thanks for ideas. I found a mobile repairman that has worked on that X frame type of hydraulic slide before and is coming out tomorrow. Thanks again Did he get it going? We like to hear the outcome... 1
oregondarrell Posted February 12, 2022 Author Posted February 12, 2022 Thanks for all your input. Jared's Mobile RV Service in Santa Rosa, CA area got me up and running. Highly recommend Two issues 1) Loose wire on relay attached to Hydraulic pump motor. 2) Bent lug and melted Insulator on power connection to pump motor, electricity was arching to case. Jared secured connection on relay and moved power connector enough to prevent arching. I plan to purchase new pump motor and have Jared replace. Where is best place to purchace HWH Spacemaker parts. Pump Motor - Part Number #08053 12 volt Thanks again Darrell 1
jacwjames Posted February 12, 2022 Posted February 12, 2022 Not sure if this is the same, it mentions a Monarch http://www.nwrvsupply.com/product/RAP13824.html
