Georgia Mike Posted February 11, 2022 Posted February 11, 2022 Getting ready for a trip and I have my Dynasty parked in the driveway. I leveled the coach and the HWH system did it’s thing and I got the little flashing light. After about 30 min I heard the system adding air to the front because my driveway is sloped it has to keep the front elevated because I have a slow leak in the front. After a few hours of this I noticed the front was going down lower and lower. I have realized that my on board compressor isn’t working. I have looked through the forum and it seems it is located near the drive axle or near the front. Does anyone know where it is on an 06 Dynasty and where the fuses are located? I only have a few days before I leave and trying to figure a solution in case my camp site isn’t level. Can’t run the refrigerator if it’s way out of level.
DrDon4u Posted February 11, 2022 Posted February 11, 2022 My compressor is located above the front axel on the drivers side. The fuses are in the electrical compartment under the driver. Thats on a 09 Dynasty. Maybe the same for you. Not easy to get to. Good luck!!
TigerMar Posted February 11, 2022 Posted February 11, 2022 Hi Mike, My fuse is in the drivers side outside fuse bay. It is a square box like fuse. Is your leak coming from the air bag? I stopped using the pump as it is very loud. I pulled the fuse. What I do is use the auto level to get it level then I change to manual. Best, gary
Garry Donohue Posted February 11, 2022 Posted February 11, 2022 My 2007 dynasty has the compressor fuse in the front run box on the right hand side. It’s a larger one, gold color.
Georgia Mike Posted February 11, 2022 Author Posted February 11, 2022 This is my front run bay… can someone point out the compressor fuse?
Larry H Posted February 11, 2022 Posted February 11, 2022 Is there a fuse box diagram pasted to the door?
TigerMar Posted February 11, 2022 Posted February 11, 2022 Mine is located on the right side of the box, not the back. It is gold in color and kind if a rectangular box . Should have a label.
TOBYLB4 Posted February 11, 2022 Posted February 11, 2022 O7 Dynasty mine is over the drive axel and fuse is under the driver. It's the first fuse on the top of the rear wall. I also pull this fuse because it runs frequently
Georgia Mike Posted February 11, 2022 Author Posted February 11, 2022 Thanks for all the replies. The only thing in my front run bay is one 15 amp and one 5 amp marked air level and they are both good. I am going to bring some wood blocks and block the frame rails where the air bags are to keep it from going down. Hopefully I will have a level site. question.. where do you plug in to air up your tanks with a compressor? I have two quick connects in my side bay with a gas and air line next to each other is that where you connect your external compressor at or is there another location?
Paul J A Posted February 11, 2022 Posted February 11, 2022 What's a "side bay" ? Could you post a picture of that?
Chuck B 2004 Windsor Posted February 11, 2022 Posted February 11, 2022 A bay on the side of the coach. 1
Georgia Mike Posted February 11, 2022 Author Posted February 11, 2022 (edited) It’s the passenger side door where the fuel tank is Edited February 11, 2022 by Georgia Mike
Chuck B 2004 Windsor Posted February 11, 2022 Posted February 11, 2022 What about on the drivers side? Depending on the year and model, on the drivers side there is also a bay access to the fuel tank.
Ivan K Posted February 11, 2022 Posted February 11, 2022 1 hour ago, Georgia Mike said: I have two quick connects in my side bay with a gas and air line next to each other is that where you connect your external compressor at or is there another location? If you have 2 air quick connects, one should be a male for air inlet and the other a female for outlet. My inlet is up front by the generator, outlet by propane tank. Not to be confused with possible propane line hookup.
vito.a Posted February 11, 2022 Posted February 11, 2022 (edited) Our HWH 12V aux compressor is located above the rear axle on the passenger side. Some of the coaches have it located above the front axle. HWH uses a Thomas 12V aux compressor. This is the same one used in dentist offices so it is very quiet. You can buy a new pump on eBay for $399. https://www.ebay.com/itm/274254098482?epid=2254404699&hash=item3fdad17032:g:De4AAOSwCH9ePY-H Or a used one for $80. https://www.ebay.com/itm/125137042791?epid=2254404699&hash=item1d22bfbd67:g:9kgAAOSwnu5iARbR There is a small blade fuse located on the pump assembly along with a White Rodgers solenoid. Picture in Post #20 https://www.irv2.com/forums/f115/replacing-hwh-auxilary-air-pump-369684-2.html The main issue is these pumps have an open armature and are not designed for dirty conditions. Some folks are building covers or relocating it. Let me know if you have any more questions? Edited February 11, 2022 by vito.a
Georgia Mike Posted February 11, 2022 Author Posted February 11, 2022 Thanks I found it in the front generator compartment
Georgia Mike Posted February 11, 2022 Author Posted February 11, 2022 So I went under looking for an in-line fuse for this compressor and I can’t seem to find one Well regardless of the fuse I just went under and Pulled apart the connector at the compressor and I had 12 V so I guess the pump is bad.
Ivan K Posted February 11, 2022 Posted February 11, 2022 Mike, I would not jump to conclusion yet, there is a couple of other possibilities in the way from power source to the motor. But, if you jump the two posts on that plastic solenoid in your second picture and the motor does not run, besides a possible bad ground, the motor is the culprit. Before junking it, I would remove the rear motor cover (two Philips machine bolts) and check the brushes. Mine were just seized in their guides.
Georgia Mike Posted February 11, 2022 Author Posted February 11, 2022 I shorted out the two terminals you said and I heard a click which I assume was the solenoid working but the motor didn’t turn so I assume it’s shot Unless it’s the brushes as you mentioned
Ivan K Posted February 11, 2022 Posted February 11, 2022 The click is from water separator drain valve which proves that you have power all the way. Checking on the brushes, collector and temp fuse is really simple, just the two little screws. Sitting twisted under the bus sucks tho...
granvillebarker Posted February 12, 2022 Posted February 12, 2022 I take the 4 9/16” bolts out and remove the whole assembly when i work on it. Its always the brushes for me. While you have it out, you can get a short wire and test it with a 12v source. I usually pop the hood and use the toad battery for testing. I did have to clean the overtemp contacts once, but be careful not to bend them. There is a thread on here about moving it inside a real bay, I plan to do that next time it stops. Or maybe over the propane tank. That would be better than next to the back wheels. — Granville Barker 1
Paul J A Posted February 12, 2022 Posted February 12, 2022 On 2/11/2022 at 10:25 AM, Georgia Mike said: It’s the passenger side door where the fuel tank is It's inside the passenger side door "compartment" may be a better word. Thanks
Georgia Mike Posted February 13, 2022 Author Posted February 13, 2022 Thanks Granville for the information about removing the unit that’s what I am going to do when I return from this trip. While I was under checking the unit it was extremely dirty, it’s a wonder it works at all. I think I will make a box or something to that affect as others have done to help protect it from the elements. Main issue is figuring out why the front bleeds down so fast…..going to have go under and spray a lot of soapy water on everything. Thanks again to everyone for all the help.
SigPIlot Posted February 13, 2022 Posted February 13, 2022 FWIW I replaced the original 'HWH' compressor with a Viair IG (Industrial Grade) 450 as the original was no longer available at HWH. Works like a d***! Though abour changing the location but decided to see how it works in the original location in front of the drive axle. May fabricate an enclosure.
RS lakeshore Posted March 12, 2022 Posted March 12, 2022 On 2/12/2022 at 12:04 PM, granvillebarker said: I take the 4 9/16” bolts out and remove the whole assembly when i work on it. Its always the brushes for me. While you have it out, you can get a short wire and test it with a 12v source. I usually pop the hood and use the toad battery for testing. I did have to clean the overtemp contacts once, but be careful not to bend them. There is a thread on here about moving it inside a real bay, I plan to do that next time it stops. Or maybe over the propane tank. That would be better than next to the back wheels. — Granville Barker I am going to remove my compressor in a few days as I have not heard in run in some time. I have not been able to find a fuse. It is the original and it looks very dirty. Could you give some pointers on removing it what to check for when I get it out. I would really appreciate it. Thanks. Richard Silcox. Ps mine is located above the rear axel
