Robert92867 Posted February 11, 2022 Share Posted February 11, 2022 I'm thinking these can wait another 7,000 miles. I just finished replacing fuel pumps and air bags and this looks like a whole years worth of maintenance. No noticeable slop in steering, no funny clunking sounds, pretty much handles as good (or bad) as the day I bought it. I hope someone with real expertise weighs in on putting off panhard bars, drag links, and tie rod ends for another season. Link to comment Share on other sites More sharing options...
Bob Jones Posted February 11, 2022 Share Posted February 11, 2022 How much play is in them? Take large pliers and 'crimp' them together to see. If your concern is the torn boots then ask about replacement boots at the auto parts store. Pretty sure they are available. But at the end of the day, the easiest way to check is use large pliers and check for play. The rubber boot is there to keep out moisture, dirt and to keep a blob of grease in there. Just because the boots are torn does not mean the actual joints are worn out. 2 Link to comment Share on other sites More sharing options...
DavidL Posted February 11, 2022 Share Posted February 11, 2022 I agree with Bob. First thing I would do is power wash the heck out of the bottom to make it more enjoyable to do the work 😉 Since each joint needs to be cleaned, booted and regreased, doesn't make too much difference to power wash them either. 2 Link to comment Share on other sites More sharing options...
Corkman Posted February 11, 2022 Share Posted February 11, 2022 8 hours ago, Robert92867 said: I'm thinking these can wait another 7,000 miles. I just finished replacing fuel pumps and air bags and this looks like a whole years worth of maintenance. No noticeable slop in steering, no funny clunking sounds, pretty much handles as good (or bad) as the day I bought it. I hope someone with real expertise weighs in on putting off panhard bars, drag links, and tie rod ends for another season. Bob S, Did you replace your airbags yourself or did you have somebody do it? If you had somebody do it how much was it per airbag to do? Link to comment Share on other sites More sharing options...
Ray Davis Posted February 11, 2022 Share Posted February 11, 2022 (edited) Robert ( Bob S ) Is that a crack you are pointing at? Is a Knight one of the coaches that had a recall of the trailing arms, if it is, were they replaced? Edited February 11, 2022 by Ray Davis Link to comment Share on other sites More sharing options...
Bjohnsonmn Posted February 11, 2022 Share Posted February 11, 2022 I am in agreement with others saying that they are likely just due for servicing. When you pull them apart to put new boots on, you should be able to inspect them for ware. If there isn't any slop, and the thing still drives like it is on rails, you should be in good shape. Inspect for cracks and bending. I also suggest taking a paint pen and mark all of your bolts and nuts when you put them back on the spec. You get a visual indication if anything is backing out or moving unexpectedly. Link to comment Share on other sites More sharing options...
Rikadoo Posted February 11, 2022 Share Posted February 11, 2022 One more thing to concider, if you cant get to replacing the boots right away, grease the joints with a quality grease, by doing that it will fill the inner voids an force most contaminants out. Most rubber seals if not kept soft an supple from grease will crack an break away. I grease my rig one to two times a year depending on milage drivin. 1 Link to comment Share on other sites More sharing options...
Tom Wallis Posted February 11, 2022 Share Posted February 11, 2022 I,m a retired mechanic and I've done lots of front end work. Here's what I'd do: with the wheels on the ground and the engine running, have someone move the steering wheel back and forth a few inches, enough to take up all slack plus a tiny bit more. You get underneath and watch all the joints for slack. If it's hard to see put your hand on each joint and feel for play. If you don't feel any significant play grease it and leave it alone. Worn out rubber covers don't indicate bad joints. Because of the amount of work to change the seal, I won't bother until the joint needs replacing. Just keep it greased. 1 Link to comment Share on other sites More sharing options...
gdroberson Posted February 25, 2022 Share Posted February 25, 2022 on the track arm that is just dust covers that have goon bad I have been trying to find replacements no luck so for and cant find new replacement ends Link to comment Share on other sites More sharing options...
dl_racing427 Posted February 26, 2022 Share Posted February 26, 2022 On 2/11/2022 at 12:06 AM, DavidL said: I agree with Bob. First thing I would do is power wash the heck out of the bottom to make it more enjoyable to do the work 😉 Since each joint needs to be cleaned, booted and regreased, doesn't make too much difference to power wash them either. I agree. I hate to work on stuff that's greasy and nasty, plus it makes it hard to prevent contaminating the new parts when everything around it is nasty. On 2/11/2022 at 12:29 PM, Tom Wallis said: I,m a retired mechanic and I've done lots of front end work. Here's what I'd do: with the wheels on the ground and the engine running, have someone move the steering wheel back and forth a few inches, enough to take up all slack plus a tiny bit more. You get underneath and watch all the joints for slack. If it's hard to see put your hand on each joint and feel for play. If you don't feel any significant play grease it and leave it alone. Worn out rubber covers don't indicate bad joints. Because of the amount of work to change the seal, I won't bother until the joint needs replacing. Just keep it greased. This is exactly what I'd do. It's just as much work to replace the boot as it is to replace the joint. Just keep them greased a couple times a year, and wipe off the excess grease after greasing, and monitor them for wear. Replace joints when they start to show play. 1 Link to comment Share on other sites More sharing options...
