Mike Farquharson Posted February 17, 2022 Posted February 17, 2022 Hi new to me 1998 dynast 34 can some one tell me what bay the inverter is in Have not been able to find it. Thanks
jfbolkovatz Posted February 17, 2022 Posted February 17, 2022 I believe it is on the ceiling of the large storage bay on the drivers side of the coach.
waterskier_1 Posted February 18, 2022 Posted February 18, 2022 On my 97 Dynasty, it was behind the main pass- thru bay. This is where the water pump and water heater are located, but on the driver's side - the inverter is on through passenger side. I had a small bay opening from the outside, but it was not accessible from the outside. - Rick Nelson
Mike Farquharson Posted February 18, 2022 Author Posted February 18, 2022 Thank you both so much had to crawl in to bay and found a panel screwed to a partition and found it behind it.
